Emprex LM2201 22" LCD Monitor Logo
Question about Emprex LM2201 22" LCD Monitor
There are 2 inches of black space on both sides of my screen.
My screen is not on wide view, so there is about 2 inches of black space on both sides of the screen.
Posted by tricia427 on
  • tricia427 May 04, 2009
    I have about 4 buttons to hit and none of them are helping other than with brightness/volume. Is there a way to get a manual for these monitors?
    Nevermind, I got it. Thanks!
Anonymous
    Problem Solver:
  • 12 Answers
There should be a way to go into the screen settings on the set (either from the remote or on the bottom of the screen). From that menu you can adjust the size of the screen, stretch it, align it, etc.
Posted on May 04, 2009
Why is there a dark smeer on my dell w3707c screen
Backlight problem. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
On either side of our screen there is a blank space about one half inch wide on each side. Can you tell me why this would happen?
You could be in 4:3 aspect ratio when you, in fact need 16:9. Look in your menu options for something that says "wide screen" or "full screen." this will change the aspect ratio to fill those gaps!
Please rate if this helped at all :)
6helpful
I just bought the tv today, it's all set up & working but the picture does not extend over the whole screen - each side has about a 6 inch blank space. How can I adjust that?
take the remote, press menu scroll through till you get to picture.... (zoom 1, zoom 2, panaramic, normal, auto and wide screen)..... please note some HD channel are in wide screen...
Black line 2 inches wide on right side 6 inches in
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
1helpful
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Can't view full screen
I am afraid your screen is on its way out.The black bar is caused by the lcd circuit failing.on that side.
1helpful
2answers
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
5helpful
Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
Top Emprex Computers & Internet Experts
Marvin
Marvin
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
