Question about D-Link DI-808HV Router (280006OB)
D-Link DI-808HV Router Problem
Yesterday I decided to download the latest firmware update for my D-Link DI-808HV router and when I installed it the router will not connect to the internet any more? My local network works but not connection to the internet. I tried resetting the router to the default manufacturer settings using the reset button in the back but it does not work? I've followed the instructions from here:
http://support.dlink.com/faq/view.asp?prod_id=1056&question=DI-704%20/%20DI-704P%20/%20DI-713%20/%20DI-713P%20/%20DI-714P+%20/%20DI-804HV%20/%20DI-808HV
But nothing? Does anyone know if this router is now dead or if there any way I can get it to reset so I can use it again? I've had the router for well over 4 years and never had any problems with it until this firmware update I did yesterday. Any help would be appreciated.
Thank you,
Mike
  • 1 more comment
  • Anonymous May 04, 2009
    Hi Palaboy,
    Thank you for your replay. My internet connection is working. I'm currently using another router to connect to the internet. I should have mentioned this in my post. I'm able to access other computers in my network but I can't access the router's admin web interface any more? So if I tryhttp://192.168.0.1 this does not work any more but yet my local network works. Any other suggestions?
    Thank you,
    Mike
    I ran the ipconfig in the command prompt and I'm entering the gateway ip address that it gives me to try and access the admin web interface which is 192.168.0.1 but it's not working?
    No luck so far. Local network works fine to connect to my other computers but the web admin interface and internet still not working. I think the firmware update I install must have killed something in the router?
DocLab
    Novelist:
  • D-Link Expert
  • 199 Answers
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Posted on Jan 06, 2017
1 Related Answer
Anonymous
  • 548 Answers
SOURCE: D-link DI-808HV - no response after firmware upgrade
Unfortunatly, from what you are saying it seems that the router is dead.
Posted on Mar 10, 2010
Update firmware
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Firmware upgrade frei dawnload
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of your router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Dir-501 firmware
How to update firmware for DI-524
How to i setup this router "D-link DI-524
Link to router information, you need to select your model revision, then you will be able to download your installation guide, firmware updates, etc
ttp://www.dlink.com/products/default.aspx?pid=DI-524&tab=3
My dlink router it worked..but the signal is off and on and off again what di i do
First thing I would do if you haven't already is update to the latest firmware. follow the link below and choose the correct model/revision of the model you own from there you can download the latest firmware as well as the manual if you need it to view how to update the firmware. It is quite easy in the interface when logging into the router. If you need further assistance please let me know. Also please take the time to accept/rate my solution when you find my assistance helpful.
Thank you,
Lee
1helpful
Working on a dlink di808hv and it wont connect to the internet
I have disk for d-link wireless router / wbr-1310 that will not load.
need interet site with download for this router. thanks
2answers
Hi. i cant connecct my VPn
- Make sure you have an updated firmware on your router and after wards kindly visit this site for further instructions:
http://support.dlink.com/faq/view.asp?prod_id=1384&question=DI-804HV%20/%20DI-804V%20/%20DI-808HV
D - Link Router and a switch
If you don't have the latest firmware for your Dlink router which is 1.43, please download it first. You may want to download the software here: http://drivers.softpedia.com/progDownload/DLink-DIHV-Firmware-Download-20625.html
Access you router by going into 192.168.0.1, then look for the firmware upgrade option. Point the location of the .bin file that you've downloaded and that should fix your intermittent problem.
Hope this helps.
Thanks.
D-Link DI-808HV Router (280006OB) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
