Question about Precor EFX 5.21s Elliptical Cross-Trainer
The crossramp and resistance buttons do not work on a precor efx 5.23
I can not change the resistance or the cross ramp but all the other buttons work
adebamoni
    New Friend:
  • 6 Answers
I will give answer letter.
Posted on Oct 29, 2015
Sportsmith LLC
  • Precor Master
  • 918 Answers
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
Precor EFX 5.23 Crossramp controls don't work
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH This could be a simple solution. It may be that the overlay/keypad is no longer functioning properly.
Repair Parts for Precor 5 23 Ellipticals Consumer SPORTSMITH net
Please have your serial number available.
Oct 12, 2014 | Exercise & Fitness
My precor 576i cross ramp will not move
Is the battery low?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Aug 20, 2014 | Precor Efx 576i Experience Elliptical...
New precore 5.33 elliptacal squeaks
bar soap on the ramps where the wheels travel until the shine wears off the wheels. I see it at warranty calls every week
Mar 24, 2014 | Precor Efx-5.33 Elliptical Machine...
CROSSRAMP ON 546i IS NOT OPERATING
If it does not plug in, yes, I would check the battery first.
Jan 17, 2014 | Precor EFX 546i Elliptical Version 4
CROSSRAMP ON PRECOR 546i DOESNT GO UP OR DOWN
I would definitely check the battery first. The battery may not have enough charge to power everything plus the lift motor.
Here's a link to the various 546i models:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Drill it down on the left side under "narrow your search" and look for the serial number prefix. This will let you find all the correct parts and information specific to your model and serial number.
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
My precor efx 546 keypad comes on, the enter button accepts all the info and programs are displayed. 1. The quickstart button does not work. 2. Both crossramp and resistance do not move either when...
1. Sounds like you need a new keypad if some buttons do not work. 2. If those buttons do not work either, it sounds like you need a new keypad, possibly the upper board. Make sure the keypad is plugged into the upper board and the connection is not corroded. 3. Older 546s used an electromagnet to produce resistance, newer 546s use a generator and resistor to produce resistance. I have never seen a 546 that used a motor that moves back and forth to produce resistance. Some residential crosstrainers use a motor like you describe.
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
Precor EFX 5.21s Elliptical Cross-Trainer Logo
801 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
