Motorola Mobility RAZR V3 Logo
Posted on Oct 06, 2007
Phone turns on screen is black
I can turn the phone on and the keypad lights up but the screen is black??? Can this be fixed?
A
Anonymous
I fixed one. Unscrew the 4 screws in the corners of the screen which are under little rubber grommets. I used a small watchmakers screwdriver. Pry the front pannel off (it will unclip, but be careful). Without this on, it worked straight away. I suspected it was an insulation problem. I got some cigarette papers and placed them over the contact areas of the phone, be liberal with it. Then, I closed it back up and rescrewed it....cliped the excess paper, and it worked fine!
A
Anonymous
1helpful
My phone's keypad just lights up for few second the moment i turn it on then turns off again without a light on the screen .can you help me fix this problem?my phone is a razr v3 model.
Hi,when a Razor v3 has a light issues isuaully caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and the light.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Motorola razr screens (small & main) are black and keypad will not light up. Phone still works though.
Hi,What causes the phone the screen of the phone to go black and the keypad light not coming on, is because the flex of the phone that is connected to the screen and allows the keypad to function is bad and will need to be replaced .When you replace the flex,the phone will work properly again.
Have a nice day
3helpful
2answers
LG XENON. Phone will turn on but screen is black
did you get it wet? if so try leaving it near a heat source for a week. like an oven, dashboard of car.... I have dropped my phone in the toilet and brought it back from the dead.
2helpful
2answers
My lg kc550 having problems turning on
take the battery out then put it in the next day dont put it back before .it worked for me hope it works for you too good luck
Sony w580i
how to remove trojan virus in my sony ericsson w580i phone
2helpful
4answers
Phone keypad lights up but no screen on
when i press some keys display will off keypad lights up but the screen does not show
Screen goes black and phone freezes.
Jessikah - take the phone and have the Flexcable replaced.
Captmartin53 - You need to reflash the phone's firmware for you.
Picture will not display on my samsung sgh-u600
Probably the ribbon that connects screen to keypad
common fault on this phone
Dropped phone
some inner connectivity might have been lost when you dropped your phone . so better take to service center
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
