I change the engine on my 07 honda civic and it wont crank it has gas and fire and it turns over but it just wont crank up
SOURCE: 1997 honda civic firing order, 4 cylinder
1.6L Engines Firing order: 1-3-4-2 Distributor rotation: Clockwise.
I hope help you with this, remember rated this post. Good luck.
Testimonial: "Thanks, runs like a charm, now!"
SOURCE: 1995 HONDA CIVIC WONT START WHEN IT GETS COLD OUT,
have someone check the engine temp switch,this is what tells the computer how cold your coolant is,so the knows to make the fuel a rich mixture for cold starts.
Testimonial: "thanks, I appreciate the help, any readings that I should specifically look for? Resistance or voltage on my meter?"
SOURCE: my 92 honda civic doesnt start the engine turns
there are a few different things it could be first thing to check would be if the timing belt is broken this is done by removing the oil fill cap and having someone else crank the engine and at the same time some one else is looking in the oil fill hole to see if the valve train is moving. if its not the belt is broken. another common problem is the fuel system main relay. or an ignitor or coil
