Question about Lexmark X2580 Wireless All-in-One InkJet Printer
I was in the middle of printing a piece of paper, when the printer grabbed every sheet in the paper tray (approximately 12 pieces) and pulled them into the printer and attempted to print on all of them. This caused a huge jam. I pulled the paper out and with it came this thin (approximatley 1/4") piece of plastic. The piece has a notch on both ends and thin, black, vertical lines going along almost the entire length of it. Ever since this paper jam, when I turn on the computer the cartridges bang against the inside of the printer and the printer errors out and I can't use it. I am not sure where this plastic piece came from or how to put it back or if this is even the cause of my problem. Can someone help?
100 percent that said small piece of plastic had give you a trouble in to your said priter. open your printer and find or locate that small plastic where come from inside your printer find the broken plastis inside your printer and join it
Posted on May 04, 2009
Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
May 20, 2012 | Canon PIXMA iP1600 Printer
Aug 09, 2011 | Lexmark X2670 All-In-One Printer
Nov 27, 2010 | Canon PIXMA MP470 All-in-One Printer
occasions.
Oct 13, 2010 | HP PSC 1315 All-In-One InkJet Printer
Aug 31, 2010 | Lexmark Z640 InkJet Printer
Aug 23, 2010 | Canon PIXMA iP1600 Printer
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
Nov 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
May 10, 2008 | Dell 922 All-In-One InkJet Printer
May 11, 2012 | Lexmark X2580 Wireless All-in-One InkJet...
Jul 06, 2017 | Lexmark X2580 Wireless All-in-One InkJet...
80 people viewed this question
