Heating & Cooling Logo
c
cyndi hugar Posted on Nov 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Peerless Boiler Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will not ignite. No noises of attempting and no light.
Joe A H.
Level 2:
Sergeant:
  • Expert 185 Answers
  • Posted on Nov 18, 2013
Joe A H.
Expert
Level 2:
Sergeant:
Answers
185
Questions
Helped
58231
Points
549
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Exact replacement for old American Standard G25 boiler?
It sounds like it has been mis-wired. The circulator pump should run all the time the boiler is on and should continue to run when heat is called for so it circulates the water in the radiators as it cools. There is normally an electronic valve that shuts flow to the radiators when only hot water is needed. Call for heat and that valve opens. It sounds like you need a mature, old school boiler / central heating technician who has lots of real world experience with older boilers.
https://www.youtube.com/@MiHeatingGuy
If you have a large screwdriver, you can use it against the pump as a stethoscope to listen for the pump running. The noise is very distinctive.
tip
Peerless boiler
This boiler us one of the best on the market!
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
1helpful
Drain and refill of New Yorker forced hot water furnace
Draining is the easy part. Isolate the water feeder (shut off). Open hose bib @ boiler, & open the expansion tank valve to pull air in to allow more water out.
Refilling- let the water feeder fill -should be around 12 Psi, then go around the building to all the baseboards or radiators & open the bleeder key valves to let the air out until you get a steady stream of water. Most of the air should work its way to the expansion tank. Turn the boiler on & test your new pump.
1helpful
Wiring Diagrams
Check out this site
www.peerlessboilers.com/Products/ResidentialBoilers/
SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
Does the boiler thermostat control the heat of the radiators as well as the hot water temperature? Does the thermostat control the water temperature and the pump - as our pump seems to be on all the...
There should be a control called an aquastat that regulates the temperature of the boiler. The thermostat will turn on the circulator to start the flow of water through the radiators. If the water coming back from the radiators is very cold, a control will shut off the circulator until the boiler can come up to a predetermined temperature then start the flow of water again. If you have a tankless coil for domestic hot water, you now have a triple aquastat that maintains the temperature for domestic as well as the boiler temp. So yes the boiler thermostat (aquastat) does control the heat of the radiators and domestic hot water. No the pump is regulated by your house thermostat. You should take an amp draw on the boiler and componants to find out what is drawing more electricity than it should and popping your fuse.
2helpful
2answers
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
1helpful
Hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Top Heating & Cooling Experts
Paul Carew
john h
