B
Barbara Long Posted on Nov 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clear code cm3520
We donated our CM3520 to a local church and they contacted us and let us know that they cannot access the copier because of the access code. Noone here remembers the code and now the church cant use it? Any suggestions on how this can be reset for them? Thanks
sethlite
Level 2:
New Friend:
  • Expert 139 Answers
  • Posted on Nov 13, 2013
sethlite
Expert
Level 2:
New Friend:
Answers
139
Questions
0
Helped
27795
Points
269
5 Related Answers
Anonymous
  • 30 Answers
  • Posted on Nov 28, 2007
SOURCE: Error code F-77-2
I cna't help unless you provide the make and model of the machine. From the looks of the number it could be a Konica but I need the model to tell you wat it means. Aloha,  Bill Monroe
A
Anonymous
  • Posted on May 22, 2009
SOURCE: Copier Only prints half the page
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
A
Anonymous
  • Posted on May 26, 2009
SOURCE: how to reset passcode, copier given to the church. Ricoh Ft 5535
This will require a tech familiar with this machine to reset. The user code option is enabled by both a setting within service mode, and a jumper being disconnected on the motherboard of the copier. This jumper will need to be reconnected and the settings changed within service mode.
Anonymous
  • 541 Answers
  • Posted on Oct 23, 2009
SOURCE: Can't scan to gmail
the issue is not the copier business but with gmail. you need to use a different mail server.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Jun 12, 2010
SOURCE: copier Sharp AR 286 Code H3-00
heat roller high temperature detection
To whom it may concern I am writing this letter on behalf of the Elim Seventh Day Adventist Church, George, South Africa. We have the BENQ MP610 Digital Projector. We are running a series of...
You have to contact BENQ with the required code numbers to get an unlock code. No one else can issue an unlock code.
Contact BENQ in your local country by going to their web pages.
2answers
I do not have a problem. I represent a church and the telescope has been given as a donation. We aer trying to find a value to sell it at a silent auction to raise money for our very tiny but active...
Let me try to help you with your question.
Allot of people use ebays seller estimator when trying to present a value on a piece like this.
If the item is in good condition with not problems I have seen them on line for $150 roughly.
Silent actions you might get that amount or a little less in my opinion.
If the item is nearly new what they call mint condition the most you will get that I have seen is $175.
Here is some tips for you.
1. Check auction site like ebay or Yahoo!.
2. Study the description and try to compare it to your donated unit.
3. Set the bid about half the going price so you get most out of the donated item.
Thanks for using Fixya.com I hope this information was Very Helpful for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Copier Hard Drive
your question is not clear so, please first clear your proble like in copy quality , paper jam , printeing problem , any service code diplay
clear your problem first and then tell
ok
i will solve your all your copier problem
2answers
Can't scan to gmail
Working HP Laserjet 5000 GN printer to give away
Thats a big printer! Have you thought about donating it to a local church, or preschool? Both do a lot off printing and have a tight budget. That will keep it out of a landfill.
MY BROTHER MFC-420CN PRINTER WAS DONATED TO ME BY MY CHURCH
You can download what you need here http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc420cn_us
BIOS access on Soyo Dregon Ultra KT400
when u start up the mobo than press the "del" key
over and over until u come in the bios
Sharp AR-C270 Copier Error code F11
Have you tried unplugging the finisher to see if that eliminated the code? Or gives you a different F code?
4helpful
Error code F-77-2
k24674
ADMIN Andrew
ADMIN Andrew
