The machine will not run it says bucket full. It is empty, tried several times to pull bucket out and put it back in to see if that helped it did not. Turned off, unplugged...nothing works. Cleaned filter, still nothing. Is there a fix?
There is a float switch somewhere to measure the level of water in the bucket. That switch is out of position or broken. This can happen if you are not careful removing and re-installing the bucket. Look at the area around the bucket and you should be able to find and fix the switch. Make sure the power is off when you are doing this.
Posted on Nov 13, 2013
SOURCE: dehumidifier reads CH 01 Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
l'';';l
Posted on Mar 07, 2011
SOURCE: I turn on the dehumidifier and the red indicator
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Mar 30, 2011
SOURCE: "My LG LHD459EL keeps registering "bucket full"-
I am sorry to hear regarding the problem. This is a common problem and unfortunately, there is no small fix for the same.This indicates that the sensor assembly is bad and would need to be replaced. Be advised that the "sensor" is the part that measures if there is water in the bucket
or not. It's refered to commonly as a bucket switch but the sensor is
the same part you'll need to order and replace.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 21, 2011
SOURCE: Stopped running
Unit will not run. Pull plug and restart will run for about 5 seconds then turns off. "bucket full" circuit seems to be the culpret. Switch checks out "OK" but light still come on and the unit will not run. Soulutions?
Posted on Jun 28, 2011
SOURCE: I have a LG dehumidifier
heatman101
Posted on Aug 13, 2011
Sep 17, 2014 | Dehumidifiers
Sep 22, 2011 | LG LHD65EBL Dehumidifier
Sep 05, 2011 | LG LHD45EL Dehumidifier
Aug 11, 2011 | Dehumidifiers
Jun 13, 2011 | Danby DDR586R Dehumidifier
May 15, 2011 | GE ADER65LN Dehumidifier
Apr 14, 2011 | Maytag Dehumidifiers
Feb 18, 2011 | LG LHD45EL Dehumidifier
Jun 07, 2010 | DeLonghi Dehumidifiers
Jun 09, 2008 | LG DH404E Dehumidifier
345 people viewed this question
