SOURCE: CDs will not load
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
SOURCE: chm -s620 cd changer not loading cds
I've got the same problem with my Alpine changer. It seems like a widespread problem, but known cause or solutions.
SOURCE: Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
SOURCE: my Alpine CHM-S620 CD changer broke down and so I
Check out www.crutchfield.com . you can cross-reference your vehicle model and they will show you what is available for your vehicle. They carry a large inventory and I have purchased from them several times.
