Question about NorStar Meridian M5009 Phone (NT4X35)
Does not ring, adjusted volume and still not ringing if you wait for a call and see the light blinking there is someone there but no ringing indicates a call is incoming
5 Related Answers
Anonymous
SOURCE: M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Posted on Jan 03, 2009
Anonymous
  • 30 Answers
SOURCE: Phone won't ring. The arrow will flash but no ring. Meridian 7310
you can try to plug it in at a set that does ring and make sure it wokrs there. The programming should not have changed with the phone but ... anything is possible. If it rings at the other location then it will be the programming for that extension. Also check that it is not in DND do not disturb
Posted on Jan 07, 2009
Anonymous
SOURCE: Phone will not ring
It's RINGING now! I followed the Set Programming instruction in our manual. It's in Configuration 3-21. It's a very old old Operator guide.
I am trying to find it online. In the mean time you can use the M7208 Phone Adminitration Overlay over the keys and program your phone by pressing Feature **266344
Here is a link to the overlay
Good Luck.
Posted on Feb 24, 2009
Anonymous
SOURCE: No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Posted on Mar 12, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Jan 12, 2010
My Samsung iDCS 18D phone will not ring. The Line light flashes, and I can asnwer calls, but it won't ring. I have tried adjusting volume levels, etc- but it seems like the ringer is turned off.
First prove it is not a faulty handset. Find someone elses phone that is the same model as yours and rings then plug it into your line. If that phone rings your handset is faulty. If the borrowed phone will not ring but flashes then it is programming
Jul 06, 2015 | Samsung Falcon iDCS 18D Display Phone with...
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Ringer troubleshoot
Is it programmed to ring in configuration programming
Jun 05, 2014 | Nortel Meridian M7208 Corded Phone
Incoming ring
Make sure the ringer is turned on on the extension. There should be a small switch either on the handset or the base that controls it. Also in the menu there could be a setting for the volume that needs to be set.
Apr 11, 2014 | NEC Lands Phones
Phones do not ring
Check the DND button- it's the far right button on the top row. If DND is not on, your ringer volume is probably turned down.
The volume is set independently per line. To set the volume:
1. Press Conf, then using the dialpad, press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2. Press one of the VOLUME buttons to increase or decrease the ringer volume.
Apr 01, 2009 | AT&T 954 Corded Phone
Some phones light up but there is no ringing...
is the ringging assignment setting
means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging
up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring...
contact yr phone provider to set the ringging assignment
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Oct 17, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
May 04, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NorStar Meridian M5009 Phone (NT4X35) Logo
97 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
