Error Code Probable Cause 12 No error detected 22 Recovery from momentary Reset 32 Lamp Cover open 33 Air Filter Cover open 34 Lamp abnormality 35 Chassis Fan failure 36 Exhaust (Back Cover) or Lamp Ballast Fan failure 37 Engine (DMD or Lamp) Fan failure 38 Excess Lamp Temperature 39 Excess DMD Temperature 41 Short Detected 44 DVI Cable (between Chassis and Engine) disc
0176 error meaning the system cover had been opened. To fix this error, you need to enter CMOS setting or BIOS setting. press F10 to save before exit. Then the error will be gone.
Did you ever open the system cover before this error happened?
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
check the error blink code again as 56 is not a valid error code for the WD62525
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
I found this list of codes Error Code Probable Cause 12 No error detected 22 Recovery from momentary Reset 32 Lamp Cover open 33 Air Filter Cover open 34 Lamp abnormality 35 Chassis Fan failure 36 Exhaust (Back Cover) or Lamp Ballast Fan failure 37 Engine (DMD or Lamp) Fan failure 38 Excess Lamp Temperature 39 Excess DMD Temperature 41 Short Detected 44 DVI Cable (between Chassis and Engine) disconnected
