Question about Alcatel OT-C701 Cellular Phone
Alcatel ICE 3 Calibration problem
I have an Alcatel ICE 3, It's calibration is not finishing and I am unable acces the Menu
2 Related Answers
Anonymous
  • 3 Answers
SOURCE: I have a Alcatel OT-880
I dont know if this will work for you, I had the same problem on the 708 model, in the end I figured out that what I thought was the aerial can be pulled out & used as a pen ,or the 'stylus'.
Posted on Feb 11, 2011
Anonymous
  • 3 Answers
SOURCE: LED calibrations are off.
1helpful
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
2helpful
2answers
Touch calibration Alcatel OT-880A
hi there, i just want to know if the problem is solved by now, cause i need the solution too cause i have the same problem with my alcatel ot 880
Dec 22, 2011 • Cell Phones
1helpful
I need to Collaborate my SAMSUNG GT-S3370?
To Calibrate the touch screen:
1 - In Menu mode, select Settings ? Phone settings ?Calibration.
2 - Tap the target on the screen until the calibration is finished.
3 - Select Yes.
6helpful
How to remove the calibration wizard on my alcatel phone
Just got the phone myself & couldn't figure it out either, It turns out that thing that I thought was an areal is a pen for it, or the 'stylus', just use that for the calibration a few times & it will work.
This for an Alcatel 708 btw.
Jan 31, 2011 • Cell Phones
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
3helpful
I have a Alcatel OT-880 mobile, my moblie touch LCD calibration suddenlt started and cannot finish it. Now the lock key and the volume key is not working
2answers
My gps touch screen does not seem to operate.I have tried resetting many many times.
try the calibration screen in the options menu and follow the directions...make sure you hold the screen over the X until it moves to the next position.
if that fails, you might need a digitizer...let me know and ill help you
further
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
bill
Standing Member of G.O.T.
Calibration
Greetings,
Sorry to hear that you are stuck?
If and when you regain the function of the menu button, you should perform a calibration. It should be done every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.  You don't have any photo paper, but it is recommended for calibrations. 2 Press Menu. 3 Scroll down until Calibrate Printer is selected. 4 Press OK. A new screen appears with Print Calibration Page selected. 5 Press Start and follow the instructions on the LCD screen to complete the calibration.
If the stuck condition presists, let us know. Best bet is to call us directly at the 800 421 6699 as our team will be able to get you running quickly.
Talk tol you soon,
Ron Baird the friendly Kodak guy
Alcatel OT-C701 Cellular Phone Logo
Top Alcatel Cell Phones Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
