Question about Maytag Washing Machines
Our Maytag Neptune MAH3000 does not advance through the rinse and spin cycles. The problem is sporadic. Sometimes it advances through one or two spin cycles and then stops, sometimes it stops on the first spin cycle, and sometimes (rarely) it runs all the way through. We replaced the timer but that did not change anything. We have never changed the original wax motor. There were no burn marks on the board evident when replacing timer. I plan to purchase a new wax motor, but am not sure if that will solve this problem. Should I replace other parts as well?
Posted by meanladyone on
Jim Chinnery
    Habit-Forming:
    New Friend:
  • 10 Answers
Have you cleaned the large drive belt, if it slips it could cause this sort of fault. Motor will stop if it doesn't get a signal from the drum. Just try wiping the drive belt with a damp soapy cloth and then wiping again with a damp non soapy cloth. You will need to remove the back, unplug it from the power before starting any work.
Posted on Apr 30, 2017
5 Related Answers
Washer_tech
Geoff Siegel
  • 164 Answers
SOURCE: maytag neptune 98 burning smell
check to see if the door boot is intact. if there is a hole in it water could be getting to the motor control board and you are in danger of shorting the machine out. the other possibility is the main computer board may be on its last legs and is doing a slow sizzle
Posted on Sep 19, 2007
Anonymous
SOURCE: maytag neptune mah3000aww
volume resistor r-11 on control board
Posted on Apr 29, 2008
fixer444
  • 106 Answers
SOURCE: MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code ''oe'',
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual, it may not be there, they want a tech to come by to make more $). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me nice or not at all. Happy spinning! Nice to watch the machine spin, not your head!
Posted on Mar 04, 2009
dumbgames
  • 109 Answers
SOURCE: maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Posted on Jul 07, 2009
Anonymous
SOURCE: Maytag neptune tl displays LL and stops during the rinse cycle
We just moved into a house with this washer. I have been noticing that things smell if you don't take them out of the washer immediately. I now read some reviews and understand the problems and most original owners had it fixed or replaced. We are out of luck. I was doing a wash last night and it's been stuck w/ 9 minutes left on code LL. I am not sure how to fix this as I don't have the manual. Any suggestions??? HELP!!! ~ KNA
Posted on Aug 14, 2009
My Maytag Neptune front load washer (about 12 years old gets stuck between 7 & 8 (minutes) in the rinse cycle and won't progress beyond.
It has reached it's use by date, It will just keep on needing repairs , save some money and buy a new one.
Jan 04, 2016 | Maytag Washing Machines
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Replace the clutch.
Mar 10, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
952 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
