Question about Toshiba Tecra 8200 Notebook
Check system.then press f1 key how solve it
To remove this message run the winows
5 Related Answers
Anonymous
  • 67 Answers
SOURCE: RTC battery "bad check sum (CMOS) message
your cios have properly lost the info.
just setup the date.. that should be enough ..
Or write to me and I will guide you.
CS.
Posted on May 19, 2008
Anonymous
SOURCE: Toshiba Satellite A60
This problem occurs when the internal battery dies and you loose data for the internal clock and possibly the bios. Refer to this link: http://209.167.114.38/support/Download/files_downloads/PSA60C/SA60EXUM.PDF and go to page 125 in the manual.
Posted on Nov 20, 2008
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: turn on computer and message reads ****bad check sum (CMOS) ****
From Toshiba Support:
Issue
When you turn your Toshiba computer on, you see an error message like:
**** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key
The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution
This condition is easy to fix in 3 basic steps:
Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery
Please follow the detailed instructions in the next section.
Procedure
Set BIOS defaults
Press the [F1] key as instructed in the error message:
In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system.
As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog.
Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save.
Charge the Real Time Clock (RTC) battery
To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not.
Other Information:
If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced.
Windows XP Desktop Cleanup Wizard
The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog.
If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows:
Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty
Posted on May 17, 2009
Anonymous
  • 828 Answers
SOURCE: toshiba satellite a60 wont start.
replace your cmos battery inside... look for a technician for assistance to remove the cmos battery and change a new one... your battery is weak already
Posted on Jun 18, 2009
hari007_in
harish katt
  • 138 Answers
SOURCE: toshiba satellite-A60 system Unit
check the cmos setting by pressing f2 or del button,, and restore factory settings, and save and exit from cmos and restart,,
Posted on Sep 27, 2009
1helpful
2answers
On my computer i have to push f1 to start it
first try to notice the message before the (press F1 to continue) message, it could be a bad component (memory, hard drive, etc...) or the time & date is not set correctly in the BIOS, this would help a LOT thank's...
2answers
Windows not opening,
I think some file is missing in u r Windows OS
better to format your system
2answers
How to go to a cmos setup in windows xp at toshiba a50
When powering on, press and hold down the ESC key, then hit F1 when prompted.
1helpful
I hit F1 key and screen is black...been in phone with Dell for over 45 minutes...help I am on another pc
when you hit F1 key it was on the Dell screen logo right? so after hitting the key F1 it just go straight black screen with a cursor?
since you where able to get display try. 1. turn off laptop make sure ac adapter is plug in. 2. while laptop is off press and hold on the Fn key then press power while pressing on Fn. 3. Check if a self-assessment will display and run on the screen. Just follow the prompt messages on the screen to guide you for the error messages which will help you to identify the problem.
1helpful
2answers
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
10helpful
4answers
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
1helpful
4answers
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
8helpful
3answers
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
flashing your bios might solve your problem
Toshiba Tecra 8200 Notebook Logo
Top Toshiba Computers & Internet Experts
Ekse
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
