SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
SOURCE: NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5%
you enter
9.5, STR, TAX+.
now it functions as (amount entered) plus tax.
Example- find the total with tax for a purchase of $14.99
14.99, TAX+
Calculator will show 16.41
SOURCE: HOW DO SET TAX RATE
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
