Question about Samsung Heating & Cooling
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at [email protected] or add my MSN [email protected]. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps
I take the time to answer your question so please rate me
Posted on Jun 28, 2010
Jul 19, 2018 | Samsung Heating & Cooling
Sep 09, 2016 | Heating & Cooling
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
Jan 24, 2011 | Samsung Heating & Cooling
Dec 15, 2010 | LG LSC183VMA Split System Air Conditioner
May 26, 2010 | Cfm Daikin R410a Split System Air...
Feb 01, 2010 | Carrier Heating & Cooling
Apr 19, 2009 | Samsung AW1003M Air Conditioner
Jul 21, 2008 | Samsung Heating & Cooling
Jul 02, 2008 | Samsung AS18A6RB Air Conditioner
102 people viewed this question
