Question about Casio Desktop Calculator - DJ-220D
Casio dj-220d thousands seperator worng
The thousands seprator (at the top) is after 3 digits and then after 2, i.e. 10'00'000
1 Related Answer
Mustgo
Vincent G
  • 2363 Answers
SOURCE: Fx-82es how we seperate digits with the help of
Yes,it's possible to program the Fx-82es to separate the digits with the help of comma.
PLEASE FOLLOW THE INSTRUCTION CAREFULLY.
If you make a mistake then please turn the calculator off and start over again.
Turn the calculator on.
GO TO Display setup screen
Disp 1
You will has two options
1 for DOT (that's not what you want)
2 for Comma (please press 2 and enter/triangle pointing to the right)
Please let me know are you able to get to setup mode and make the comma change on reply.
Posted on Jan 24, 2011
How do i round numbers to the nearest thousand?
Identify the digit that sits at the THOUSAND position.
All the digits at the right of it will be replaced by zeros.
The THOUSAND digit itself may be left unchanged or increased by 1, depending on the digit that sat at the HUNDRED position.
If the digit at the HUNDRED position is 0, 1,2,3,4 the digit at the THOUSAND position is left unchanged.
However, if the digit at the HUNDRED position is 5,6,7,8, or 9, increase the old value of the digit at the THOUSAND position by 1.
Examples
5768 469 becomes 5768 000
5768 743 becomes 5769 000
5769 469 becomes 5769 000
5769 743 becomes 576 (9+1) 000 Patience
9+1=10, so you must increase the 10-THOUSAND digit by 1
Thus 5769 743 becomes 5770 000
If any other digit to the left of the THOUSAND digit reaches the value 10 (no digit), then increase by 1 the digit at the left of it.
Sep 09, 2014 | Computers & Internet
How can i round to the hundreds or thousands?
Put the calculator in scientific display mode (SHIFT>MODE(Setup)>FIX. You will be asked to enter the number of fixed decimal digits. Enter 2 for hundredths, and 3 for thousandths. To round to the nearest hundreds or the nearest thousands, do it by hand as follows.
For hundreds
Locate the hundred digit. Let it be h.
If the next digit (the tens digits is less than 5 replace the 10 and unit digits each by 0. Your result will look like ...h00.
If the 10s digit is 5 or above (5, 6, 7, 8, 9) you must round up by increasing the hundreds digits by 1. Your result will look like ...(h+1)00
For thousands
Let the thousand digits be t
If the hundreds digits to its right is less than 5, replace it and the digits following it by 0. Your result will look like ...t000.
If the hundreds digit is 5 or higher, increase the thousands digits by 1 and replace the hundreds, tens, and units digits by 0. You result will end with (t+1) 000
Note if (h+1) or (t+1) give you 10, put a zero at their positions and increase the digit to the left by 1.
Example. 78997 to the nearest hundreds 78997 becomes 789(9+1)0 or 78(9+1)00 or 79000
May 22, 2014 | Casio FX-115ES Scientific Calculator
Give the number whose hundreds place isnone third of the greatest one digit
The answer is :
108,366
Just walk your way through it a piece at a time
hundreds place: 1/3 of 9 = 3 (9 is the greatest one-digit number)
tens place 2(3) = 6
ones place: 4(3) / 2 = 6
thousands period = 3*6*6 =108
final number: 108,366
Jun 26, 2012 | Computers & Internet
I want thousand seprator in my answer
Sorry, the fx-570ES Plus does not have the ability to insert thousands separators into numbers.
May 11, 2012 | Office Equipment & Supplies
What is the new number formed if in the number,7 348,the thousands and the ones digits are interchanged?
If you interchange the thousands and the ones, you get 8347. Why? In the former, 7 is the thousands, 3-the hundreds, 4-the tens, and 8-the ones. As simple as XYZ. I hope this helps. Thanks for usiing Fixya.
Jul 04, 2011 | Computers & Internet
What is the answer of this problem? I am a four digit number. My ones is twice my tens. My hundreds is five less than my ones. My thousands place is the sum of my tens and hundreds. What number am i?
There are two possible answers to the above question, 4136 and 7348.
4136
My ones is twice my tens: The 6 (the ones) is twice as big as the 3 (the tens).
My hundreds is five less than my ones: 6 (the one) - 5 = 1
My thousands place is the sum of my tens and hundreds: 3 (the tens) + 1 (the hundreds) = 4
Jun 26, 2011 | Office Equipment & Supplies
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Want to know what is the valve clearance of bajaj ct-100 m/c?
get the engine on top dead center, take valve caps off turn over engine slowly until intake valve just closes u will be close to top dead center there. then i use a small long screwdriver i put in sparkplug hole and turn engine very slow when piston just startes to go back down i adj valves. intake valve 3 thousands and ex valve 5 thousands
Nov 18, 2008 | 2007 Bajaj CT 100
CREATIVE ZEN
You need to do 2 seprate processes, convert and SEPRATELY put it on youre zen. If the conversion process is slow, dont worry. I converted a show and it took 13 hours!
Feb 13, 2008 | Creative Labs Zen Digital Media Player
Casio Desktop Calculator - DJ-220D Logo
802 people viewed this question
Top Casio Office Equipment & Supplies Experts
Ekse
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
