Question about iLO MP3 Player
Cd program Hello, I bought the ILO mp 3 player a year ago. I moved and during the move I lost the cd program it came with. Is there anyway of downloading the software or can I get another cd shipped to me? Thanks, Marianne Staples
Posted by mstaples2 on
  • mstaples2 May 03, 2009
    Thank you so very much! I love my mp3 player and was sad to think that I couldn't download anymore music because of a moving company!
    Marianne
  • elys_777 May 25, 2009
    i dont know how to work w/my ilo mp3. :(
rohit asthana
    Sergeant:
  • 258 Answers
Hello friend
you can download cd here
http://wareseeker.com/free-ilo-mp3-player/
thanks
Posted on May 03, 2009
  • rohit asthana
    rohit asthana May 04, 2009
    helllo friends
    if you satisfied with solution then rate us..this will help us to give your answer frequently
    thanks
USB cable lost need a replacement
If it a normal USB cable, any usb cable with the correct end should work. It might be something else.
Also, NEVER ever put your phone number online, or your last name.
Dec 01, 2008 | iLO (2 GB) MP3 Player
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Sep 18, 2007 | iLO MP3 Player
Tried connecting DVD player to ILO 27 in, no go
go to video on your remote, then go to composite... it should work on composite mode. Took us a while, don't feel bad. Hope that works for you.
Nov 14, 2008 | iLO 3200 32 in. LCD Television
Hi lost cd that came with player
http://www.downloadatoz.com/search.php?q=iLO+2+GB+MP3+Player
i guess this is the website for u
Hope it helps
Have a nice day!
tc
Jun 12, 2008 | iLO (2 GB) MP3 Player
Need to redownload for mp player lost disc
Unfortunately, this is the worst Mp3 player ever made EVER. ILo/Walmart do not have the software on any website that anyone can find. If it is still in warranty (less then 1 year in some cases), call the number in your documentation (or call Wal-Mart), and find out about getting a new CD or new player sent to you.
May 28, 2008 | iLO Audio Players & Recorders
Ilo mp3 player model mp-556
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 04, 2008 | iLO (2 GB) MP3 Player
Ilo won't turn on.....
Sep 18, 2007 | iLO (2 GB) MP3 Player
ILO MP 3 player
With the numbering, DO NOT put it as 1 2 3 4 5 etc. Instead, use 01 02 03 04 05 06 07 08 09 10 etc. That will solve it.
Aug 27, 2007 | iLO (2 GB) MP3 Player
159 people viewed this question
Top iLO Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
