Question about Stanley Utility Knife
Cant work a Stanley 10-499
How to get blade to work
How to change stanley 99E blade
Hello, Go to this youtube website too see video on changing the blade.
Jan 01, 2014 | Stanley Bostitch 10150 Straight Handle...
How do i change the blade on the stanley box cutter fat max?
Push the blade out as far as it will go and hold in the button on the side while slideing blade in and out.
Apr 20, 2012 | Stanley Hand Tools
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
How do i change the blade on the stanley 20-115 hacksaw?
The 20-115 uses a quick release lever at the front of the saw. Opening the level by hand with a forward motion will unlock the blade tension allowing you to replace the blade. Pull the level closed to restore tension to the new blade.
Oct 28, 2010 | Stanley Hand Tools
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
STANLEY QUICK POINT BLADES...CAN'T FIGURE OUT HOW TO CHANGE.
There is a SLOT in the end of the knife. Simply insert the strip of new blages in to the slot and you are ready to go.
Good luck. :)
Apr 25, 2009 | Stanley Hand Tools
Stanley  Utility Knife  Logo
453 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
