If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. You can try plugging it into iTunes to see if it reboots itself. iOS Forgotten passcode or device disabled after entering wrong passcode
SOURCE: How do you unlock a
As you have forgot the passcode you will have to restore the iPhone using iTunes. Note: This process will wipe all data from your iPhone 4. You may be able to sync most of the data back once you have restored it. 1. With the iPhone 4 disconnected from your computer, power it off. Press and hold the Power button on the top of the device for a few seconds, then slide the red slider. If this method doesn't work, press and hold the Power and Home buttons for a few seconds until it goes off. 2. With the iPhone 4 off, press and hold the Home button while connecting it to the computer you registered it from. It should then power on. 3. Keep holding the Home button until you see a Connected to iTunes message appear on the screen. 4. Open iTunes and it should provide a message about an iPhone connected in Recovery Mode. 5. In iTunes, select the Summary tab and click Restore and follow the prompts. 6. You may attempt to sync your iPhone back to your iTunes to restore any data lost in the recovery process. I hope this helps! Thank you for using FixYa!
SOURCE: i have forgotten my passcode
Hello Dass,
Press and hold down the Sleep/Wake button and Home button simultaneously
for at least 10 seconds; the screen will clear out and then the Apple
logo will appear on the black background. When the logo appears it means
that reset is done.
SOURCE: IPhone 3G passcode forgotten? anyways?
your iphone 3g is avelebale plice request is castmare care the 3g satting on your hensets ok. Thanks you
SOURCE: I have an iphone 4s. I did updates on my phone &
you can do a factory reset which will wipe the passcode you will need to plug it into itunes then put it into recovery mode and in itunes look for the reset button and go from there
