Question about Casio FX-300MS Calculator
Canverying polar to rectangular
How to convert rectangular to polar coordinates. and vise versa
Posted by sravyanaidu_ on
  • Anonymous Mar 27, 2014
    when ever im doing polar and rectangular coordinates why is it that the degrees is so different from when I see it plugged in on internet examples.Its very frustrating because I feel im being mislead by my calculator.
k24674
  • Casio Master
  • 8,091 Answers
Here are exemples from the manual.
Posted on Sep 25, 2009
How to covert from polar to Rectangular
Let use an example to convert from polar to rectangular. There may be other ways to do it on this particular calculator, but this should work on all calculators.
Let's use 20 degrees and 5 units for our polar.
Sin 20 degrees = y/5, cross multiplying we get y = 5 sin 20 degrees.
Similarly, Cos 20 degrees = x/5. Cross multiplying we get x = 5 cos 20 degrees.
Thus, I get (1.71, 4.70) as the rectangular coordinates of the point.
Good luck.
Paul
Nov 06, 2015 | Canon F-603 Calculator
Convert a polar equation to a rectangular equation?
To convert a complex number (not an equation) from rectangular coordinates to polar coordinates you do as follows
2+3[OPTN][ F3 (CLPX)][F1(i)][F6 >][F3> r ,theta][EXE]
Nov 08, 2014 | Casio CFX-9850G Plus Calculator
How to add polar and rectangular form on calculator?
You cannot add rectangular coordinates to polar coordinates. You can only add rectangular coordinates to other rectangular coordinates. For polar coordinates you must use some specific trigonometric formulas.
Sep 23, 2014 | Casio Office Equipment & Supplies
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
How to use pol ?
The Pol function converts coordinates from rectangular to polar. Pol(x,y) converts the rectangular coordinates (x,y) to polar coordinates (r, theta).
For examples and instructions, see page E-37 of the manual and example #036 in the Appendix.
Dec 07, 2012 | Casio FX-115ES Scientific Calculator
Casio fx 82 au plus convert polar to rectangular
To convert from Polar to Rectangular
PRESS [SHIFT and -Rec] then enter the coordinate and angle
e.g. [SHIFT and -Recl]
Rec(15,0)=
r=15
0=0
Jun 18, 2011 | Casio FX-115ES Scientific Calculator
Convert from polar to rectangular & vise versa using calculator with RCL&POL GIVE EXAMPLE JUST PROCEDURE THANKS 9
Examples #036 and #037 in the Appendix illustrate how to convert between polar and rectangular coordinates. If you need the appendix and/or the manual, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
May 22, 2011 | Casio FX-115ES Scientific Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-300MS Calculator Logo
1,071 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
