Vehicle Parts & Accessories Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instalation manual VIPER DEI 300 CAR ALARM
Jim Goldsmith
Level 3:
  • Master 2,005 Answers
  • Posted on May 03, 2009
Jim Goldsmith
Master
Level 3:
Answers
2005
Questions
Helped
736255
Points
6152
Http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
2answers
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Need to program rpn471t but I don't have a valet button in the car
Hello Lacey,
The only way to program an additionally remote on one of there systems is with a valet button. I would recomend that you contact a local install shop like Best Buy that works with DEI products. They likley will be able to program the remote for you.
My Viper Alarm started going off while I was driving. I pulled over, shut everything off. Got out of the car and closed the door and locking and unlocking the vehicle wouldn't shut the car off. I opened...
The alarm may not be going off. Rather it may be a malfunction of the relay that is driving all the sirens and piezo. Next time it happens check for flashing parking lights. They will flash only when alarm is going off. Also ignition input to the alarm prevents this alarm from going off while driving. Panic from the remote can still be triggered. Got to play detective....
Viper alarm(car) when replace batt(car)alarm goes off like crazy
should be able to close everything on car and just hit the unlock button should disarm if not you may have to hold the valet switch to reet
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
Hope some or all of this helps you!
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
1helpful
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
2helpful
2answers
Does anyone know the operation of a Viper Car alarm and it's settings? where can I get instructions! please help!
go to viper.com and look under the support tab and then the guides tab...
if you have the alarm model number, you can download a fresh updated guide for your alarm...
Print a copy to keep with you..
K
I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
