Question about Lorex 4 Channel Business & Home Security Digital Video Recorder with 80GB Hard Drive
Lorex lh114000 dvr is flashing light
Lh114000
1 Related Answer
mrb4rbz
dingledick
  • 166 Answers
SOURCE: I have Lh126000 lorex dvr. After upgrade can't login in to dvr how to restore dvr without login
u need to conect it to internet. login signals canot pass thru walls
Posted on Sep 08, 2016
Lorex model LHV221600. Where can I obtain an owner's manual?
https://www.lorextechnology.com/downloads/security-dvr/LHV1000/LHV1000_SERIES_MANUAL_EN_R2.pdf
How do i reset lorex LH114000?
you can remove the outer cover of the dvr and find 3.5v battery remove it for 5 sec and the return it back (at power off mode)
I have a Lorex edge LH314 320GB, DVR beeps and displays HDD is not formated.
You need to format the hard drive using the built in formatting utlity. Did you replace the hard drive in the DVR maybe?
4answers
Lorex password
Should be1234 unless u have changed it
Does the lorex dvr support my MAC os on my pc
Hi Kavya,
Which model of Lorex DVR are you using? Currently, only some of our security DVRs are compatible with Mac OS X (via Safari). Our line of Edge and EDGE+ DVRs (LH300 Series) are Mac compatible and offer full remote viewing, playback, backup, and setup using Safari.
Please give us a call at 1-888-42-LOREX(56739) or visit us online at www.lorextechnology.com
Cheers, Lorex Support Team
I have 2 lorex dvr's. both need web access, can it be done
there are a few ways to accomplish this. one way is you will need more then one static ip. one static ip for each machine, you will then be hitting them on the same port but different ip's. the simplest way is to change the web port setting in the lorex dvr from 80 to something else in the second machine.
1helpful
2answers
Cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Lorex 4 Channel Business & Home Security Digital Video Recorder with 80GB Hard Drive Logo
Top Lorex Home Security Experts
ADMIN Canada
ADMIN Canada
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
