Question about KitchenAid KEMC377K Convection / Microwave Oven
Kitchenaid superba microwave convection buzz
Buzzing sound burning smell
2 Related Answers
bruce harrod
  • 112 Answers
SOURCE: Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Posted on Oct 25, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Posted on Dec 22, 2009
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
Aug 30, 2016 | Maytag MMV1164WS Microwave Oven
Buzzing sound when you turn on .also smells like burning
The magnetron is failing, "heats food" and in some cases gives off a burning smell, "classic symptom" repairs will run close to a new microwave oven or more.
Jun 07, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave makes a loud buzzing noise and emits a burning plastic smell
This indicates the magnetron has failed, buzzing sound and odor are classic symptoms. It is cheaper to replace than have it repaired.
Apr 03, 2011 | Kenmore Microwave Ovens
Everything works except the Microwave. Even when you start the Microwave the table turns etc but no heat. Was making a buzzing noise then burning smell.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 14, 2011 | GE JVM1790 1000 Watts Convection /...
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Advantium 120 makes low buzzing sound all the time
this is the transformer that is doing it and it may end up failing soon , and should be replaced before any other dammage is done,
Nov 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
KitchenAid KEMC377K Convection / Microwave Oven Logo
56 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
