Question about Rival VS230 Seal A Meal Vacuum Food Sealer
Nedd the new tape for a seal a meal machine, rival
Where can I get the new tape?
Posted by Vicky Rose on
Nikki R
    New Friend:
    Problem Solver:
  • 9 Answers
Dated: Wednesday, November 20th, 2013
Call:
Rival Customer Service at 1-800-557-4825
Posted on Nov 20, 2013
3 Related Answers
Anonymous
SOURCE: Had a Rival VS110 Seal-a-meal vacume good sealer
you have to push down with a lot of force to get the rubber seal to give enough to allow it to latch...
Posted on Nov 28, 2010
GetMeOttaHere
  • 2926 Answers
SOURCE: Hi I have a RIVAL
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Posted on Dec 22, 2010
Anonymous
SOURCE: I just got a used Rival Seal-A-Meal model VS220.
VS230. Here's a link:
http://www.sealameal.com/customer/manuals/
Posted on Feb 12, 2011
Where can i get a new heat tape for my seal a meal
Crazy,, I've only used it three times and the heat seal already went out,,, will never buy this product again
Apr 29, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012)
Sep 02, 2011 | Rival VS107 Seal A Meal Vacuum Food Sealer
Stopped sealing the bags, does not vacuum 3 week old machine
Did the clip break that holds the sealing nozzle in place? If so, use a chopstick to hold the lock and seal unit in place. I place a little scotch tape on the chopstick, place it all the way across the sealing nozzle. You may have to really press on the lid to shut it, but it works. If it's not the clip, maybe you have a blocked hole or the sealing unit needs cleaned out really well. Good luck!
May 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
Nov 30, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
Rival VS230 Seal A Meal Vacuum Food Sealer Logo
469 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Colin Stickland
Colin Stickland
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
