GE has a new bail arm that will correct this issue, check with your local part house, this part is under 20 buck and will correct this issue for you.
I hope this helps, get me the complete model number and I can research this and get you the part number if you like.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: Ice maker spills ice
SEE IF THE CANAL OR HOSE . WHO FILL THE ICE MAKER INSIDE ITS PROPERLY SET. COULD BE NOT PROPERLY ALIGNED OUT OF THE POSITION OR MISSING
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
SOURCE: GE Monogram ZICP360SRSS - Ice cubes spill out of icemaker bucket
sorry, but not unless you want to get into spending some serious time.
SOURCE: water drains internally at back of freezer drawer
Check the drain.
Take the bottom drawer out of the freezer and look in the very back for a drain hole. It may be covered with ice. A hair dryer will melt the ice so you can unclog the drain.
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
SOURCE: our new GE Profile refrigerator makes too much ice
there is a kit you can git to put on the arm that tells how much ice it has ..or you can carefully bend the arm down too tell it it is full hope this helped
