Question about Sony KV-35S42 35" TV
No vertical sweep
Sony kv-29f1u no vertical sweep, the screen goes to a single horizontal line then the video signal muted. indicator flashes - continues to flash red
4 Related Answers
Anonymous
  • 173 Answers
SOURCE: sony tv kv-29F1U
tuner needs replaced or taken apart and cross your fingers soldering joints, use silver solder look hard with magifiers for solder cracks or bad joints and grounds inside tuner.
Posted on Jan 18, 2008
Anonymous
  • 74 Answers
SOURCE: Sony Trinitron KV-36FS76U continuous horizontal flashing lines
Try adjusting the screen control on the flyback.
Posted on Mar 27, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Sony KV-28HX15U
Most likely the flyback assembly, and or the horizontal output transistor failed. There is also a possiblity of some other faults that are putting the power supply in to the protect mode.
If there is a scan failure, it is possible that there is also some damage in the power supply.
The set will have to be serviced by a TV service tech.
Jerry G.
Posted on Apr 19, 2008
kirtec auto
  • 1348 Answers
SOURCE: Sony Trinitron TV KV-XA29
the vertical output ic or one of the 4 capacitors around it no good.
Posted on Jul 18, 2009
Light blinking 4 times and no picture
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
If you wish to get more details, check the site linked here.
Nov 27, 2013 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Kv 27542
  1. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Jun 27, 2013 | Sony Televison & Video
Sony KDFA42A-10 standby mode
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony TVs are described in detail.
Apr 07, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
KV-34hs420 LED Blinks 4 times
Apr 28, 2012 | Sony KV-36XBR400 36" TV
Red light blinks 4 times, no video or audio
Apr 27, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony kdf50e2000 will not stay on red light blinks 4 times
Mar 03, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a sony trinitron kd-32fs170....all i get is 4 red blinks no picture
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
No frame in other words.
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
Check IC1509, Q1505
Please rate this solution
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Sony KV-35S42 35" TV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
