Question about Lexmark X7350 All-In-One InkJet Printer
Printer won't turn on. I just used it a couple days ago. Checked power supply. Does it have a fuse or a reset button somewhere?
Posted by mirrorimage9 on
Roopesh S
  • Lexmark Expert
  • 228 Answers
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Posted on May 03, 2009
My aftermarket cd deck won't turn on in my Honda Civic. The Stereo is a Sony Xplod CDXGT700HD. I checked the fuse and replaced it for the hell of it. I tried using the reset button. I saudered all
You might want to check all of the fuses in the car. There should be a fuse box in the engine compartment and another under the dash somewhere.
Mar 21, 2012 | Car Audio & Video
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 30, 2011 | Kenmore Dryers
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
I have a Sharp Projector model XG-E3000U that won't power on. Nothing happens at all when you turn it on. No lights, no fan, nothing. I opened it up and checked the fuse and that's good. Is there a reset...
the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 18, 2010 | Sharp (CLMPF0046DE01) Projector Lamp for...
Proscan ps35653 will not turn on after recent move
yes it could be the problem of power supply.
Aug 31, 2008 | Proscan PS35660 TV
4L has died?
time to give it a decent burial..parts on those old 4L's are mostly drawn from others that are no longer functioning..
maybe you ought to have an HP wake, and a decent burial?
at any rate..that sounds like a power supply board went zonko..
Mar 21, 2008 | HP LaserJet 4L Printer
Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Dec 12, 2007 | Apple LaserWriter 8500 Printer
Lexmark X7350 All-In-One InkJet Printer Logo
365 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
