Question about Epson WorkForce Pro WP-4540 Color Ink-jet
Yellow leak problem, Any solution? - Epson WorkForce Pro WP-4540 Color Ink-jet
Posted by Yerry Batista on
Martin Smallridge
  • Epson Master
  • 419 Answers
Unfortunately this is a known issue with these printers and caused by faulty printer manufacture.
You can see what I mean if you do a search on Youtube to find videos like this:
http://www.youtube.com/watch?v=OIVNTMt0ua8
The only solution is to contact Epson and get a replacement, assuming they'll honour their responsibility.
Posted on Nov 12, 2013
I have 2014 Montana 3735mk looks like a leak by my rear 2 hydraulic Jacks but it is a yellow oil. What is back there that contains a yellow oil that could leak?
a lot of hydraulic oils are yellow or honey coloured so it may be a seal that is leaking
check to see if it is still under warranty and have a service dealer check it out.
Aug 14, 2015 | Cars & Trucks
Leaking yellow fluid
Dog or cat peed on it. Or liquid is coming from washer. There is no liquid in a dryer to leak out.
Sep 11, 2014 | Whirlpool Dryers
Yellow fluid leaking onto serpentine belt
yellow fluid is most likely anti freeze. check the radiator hoses but because of the location, my guess is that it is the water pump leaking. make sure you change the tension pulleys when you change the pump.
May 03, 2014 | Dodge Grand Caravan Cars & Trucks
Water still leak inside and not stop at level
ok more info needed
if in passenger side compartment you have a heater core leak
if outside to engine you have bad gasket
if the water not leaking there then you have bad resevior the resivor should be white in color not yellow if yellow replace resevior
Nov 09, 2013 | Cars & Trucks
The yellow fluid is power steering fluid, the noise is because it is low. Repair your leak asap to prevent pump damage, not to mention the safety issue when you lose the power sterring
Feb 27, 2013 | 2002 Jeep Liberty
Red /yellow cloured oil leak around behind front wheel line
if it is yellow it could be the aircon compressor, if it is really red to pink, power steering or automatic transmission leak
Jan 08, 2010 | 1997 Mercedes-Benz E-Class
Yellow malfunction
I'm afraid not. The printer expects all three cartridges to be present. If a cartridge leaks, you might be able to return it for an exchange if it's relatively new. Cartridges shouldn't leak at all.
Jul 02, 2009 | HP Color LaserJet 2600n Printer
OIL PRESSURE GAUGE AND YELLOW FLUID LEAK
isw this leak inside car or outside ,yellow fluid sounds like antifreeze
Apr 07, 2009 | 1989 Jaguar XJ6
Yellow Toner leak inside printer
I generally use small soft-bristle brushes to move the toner to locations where I can easily get to it with a small hand-held vacuum unit and just **** it right out.
Apr 07, 2009 | HP Color Laserjet 3550 Printer
Cleaning a whirlpool tub
The jets turn yellow from exposure to the sun, not much you can do except replace the jets (costly). What is leaking? if you broke the seal on a jet it will leak and have to be resealed.
Mar 24, 2009 | Home
Epson WorkForce Pro WP-4540 Color Ink-jet Logo
88 people viewed this question
Top Epson Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Rob Hill
Rob Hill
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
