2003 Pontiac Aztek Logo
H
HARV VAN VLEET Posted on Nov 12, 2013
Front brakes continue to squeak.
Recently replaced the front brake pads, assuming they had worn down. When I removed them they still had 80% of wear remaining, all even ware. I replaced anyway. There remains a squeaking noise while slow rolling as well. Brakes function as they are supposed to, but the squeaking continues to drive me crazy..lol any help would be appreciated. brakes are semi metallic, if they made a ceramic brake pad would that solve the problem?
  • Jane Deere
    Jane Deere Feb 01, 2014
    dude, i did the same thing, break lines. the breaks aren't the problem
kevinr210
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 12, 2013
kevinr210
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
5472
Points
23
To help with pad squeel when you take brake pads out clean all rust from the caliper where the pad slides and put some copper grease on the areas that contact this should help, while you have caliper off check the slider pins too as they may have rubber stuck to them, if they do buy new pins or scrape rubbish off and copper grease them up too, hope this helps.
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 04, 2009
SOURCE: How do I change the rear brake pads on a 2005 Pontiac Bonneville?
remove the caliper bolt, swivel the caliper up and slide off the rod. To push the caliper piston in to accommodate the new pads, you must get the tool to TWIST the piston in while slightly pressing the piston. Check with your local Murrays, Auto Zone for the tool loaner program. Gm W-Body rear caliper tool. Good luck
Anonymous
  • 3006 Answers
  • Posted on Oct 02, 2010
SOURCE: changed front brake pads now brakes are spongy
If the brake discs (US=rotors) were anything less than perfect then some sponginess is to be expected, but if the discs were heavily scored or worn they should have been replaced or refaced on a lathe (as long as they have sufficient remaining wear left to allow for this). It takes up to around 250 miles to fully bed in a new set of pads to a worn disc and until then the brakes will not be fully efficient. Hard braking should be avoided and the key to bedding in correctly is to brake earlier than usual and apply them more lightly than normal. This prevent glazing of the high points on the pad which will reduce braking efficiency and also slow or even prevent the pads from fully bedding in.
If the sponginess does not soon start to reduce or is more than a slight effect, then you have a different fault and will need to try bleeding the brake lines. Air should not have got in during a routine pad swap though so if any is present it suggests that the seals in the calipers are faulty and further investigation will then be a matter for urgent attention.
I hope that my reply has been of use to you and that you only have to bed the pads in for the problem to disappear. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Anonymous
  • 4 Answers
  • Posted on Jan 06, 2012
SOURCE: knocking/thumping noise in rear end while breaking
I HAVE THE SAME PROBLEM I'VE BEEN DOING A LOT OF RESEARCH ON IT AND I THINK ITS GONNA BE THE BUSHINGS IN THE REAR KNUCKLE ASSEMBLY AND YOUR HAVE TO CHANGE THE WHOLE ASSEMBLY. I HAVEN'T TRIED IT YET BUT IF YOU CHECK BACK IN A COUPLE DAYS I WILL LET YOU KNOW
2014 Chevy Cruze. The cost of front brakes and rotors please?
About Brake Pad Replacement Please note: Pricing shown is for either front brakes or rear brakes. Made of ceramic, organic or metallic material, brake pads squeeze against the brake disc rotors to slow the vehicle down. Every time you apply the brakes, the pads wear down a tiny bit. Eventually a wear indicator starts squeaking to tell you it's time to replace the brake pads. It's always better to replace the pads before they start squeaking, to avoid damaging the brake rotors. A mechanic can check brake pad thickness during a tire rotation or other service. The number of miles you can go before replacing the brake pads really depends on your driving style.
Total Estimate
Parts
$90 - $108
Labor
$137 - $161
New brakes squeaking
Sounds like you may have had soft compound brake pads before and now been replaced with metal compound pads.metal pads great for long wearing and long life but squeal a lot and are harder to stop the vehicle.
you can try to give front brakes a good pressure wash or hose the dust off as this is usually the reason for the squealing.
1helpful
3answers
Brakes are going to the floor most of the way checked rear brakes and they are still good bleed them and problem still there
Normally when the brake pedal goes almos to the floor it is an indication of low brake fluid. Low brake fluid is an indication that front and/or rear brakes are wearing. As the brake pads wear down more brake fluid will be required in the wheel cylinders or calipers. Hint, the front brakes usually wear much faster than the rear due to the fact that the fronts due a much greater braking function that the rear. Check the front pads. Don't let them get down to the metal scraping metal stage before you change them out. This causes unnessary damage to the rotors. Look at your master cylinder on the firewall under the hood in front of the steering wheel. If the fluid level is belowhte "max" mark add fluid. Low fliud should also show as a red "brake" light on your dash, but not always.
When braking between 80-60 kph the steer is
You could have a worn idler arm and pitman arm. The idler arm is more common to wear out before the pitman arm so start with that and have the front end aligned. Inspect all your front end steering components for damaged and worn out parts that need to be replaced.
Thank you for using Fixya, you did replaced your brake rotor when you replaced the brake pads right???
2helpful
3answers
My left front wheel squeeks until i press the break pedal
Most likely the brake shoe in that wheel is worn down to the rivets and those metal rivets are scraping on the drum. If you have a new brake shoe installed right away you will be ok. if you wait, you may also have to have the drums turned. By the way brake shoes come in pairs so they will change both front brake pads. Joe
2answers
Sueaky front wheel
It could be a number of things. First check your brakes for any rocks or excessive dirt. Second, check to make sure you are not in need of new brake pads. Brake pads are equipped with a tab that starts making noise when its time to replace your brakes. Third, have the bearing checked. Once the bearing get excessively worn they will start making a squeaky sound. Also have the shocks checked. the bushing worn out in shocks can also cause the noise. The best bet is to have your local mechanic inspect your front end for any wear. Once he does this, he can compile a list of parts that need replaced. Then you can replace or fix it yourself.
2helpful
2answers
Squeak from front left wheel...
It could probabely be the brake pads ,some cars have worning light come on and others have this little projection of steel piece working as warning tht the pads needs replacement.
Remove the front wheel andyou will be able to see the brake calipers and the pads.
Good luck.
1helpful
Consistent Wheel Squeaking - Right Front Wheel
This may be a worn down front brake shoe or pad, some after market pads come with a wear indicator.
This wear indicator rubs the rotor when the pad is in need of changing.
Squeak in left front end
i would still bet youre dealing with worn brake pads, theres an off chance it has a bearing issue but brakes are first thought. maybe has caused them to wear down quicker ie. holding caliper, restricted flex hose, or even economy parts from previous repair.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
