Question about Nikon Coolpix S3300
Nikon cool pics totally dead
No life in camera at all and wont charge
Posted by Jonathan Hudson on
Harrie
    Top Expert:
  • Nikon Master
  • 6,746 Answers
The battery is most probably defect. and then,
The manual says:
Battery is exhausted.
When connecting to an electrical outlet using a Charging AC Adapter, the camera cannot be turned on.
  • Confirm all connections.
  • Off is selected for Charge by computer in the setup menu.
  • When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
  • When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
  • Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So even when you think the battery is charged, it still can be empty. When a rechargeable battery is old, or not often used, it can lose its capacity, not being able to power the equipment it was meant for correctly.
To make sure your battery is good, you could try to check the voltage with a multi meter. The voltage should be slightly higher than the 3,6 Volt that is printed on the battery. like 3,8 Volt, when measured. if it is just a fraction lower than the 3,6 is is not fully charged and it will be much lower when put in a camera, after switching on the camera. When you measure 2,4 Volt, 1,2 Volt or even nothing you can be sure the battery is dead.
Best option then, would be to order a new battery. But if you know someone with a camera that has the same battery that works, ask if you can check your camera still works with a battery that is ok. because when in a rear situation it is you camera that is defective, you can save the mont for a new battery and look out for a new camera, because the batteries are not cheap.
Posted on Nov 12, 2013
4 Related Answers
Anonymous
  • 1027 Answers
SOURCE: my Nikon D50 camera says
It thinks that the SD card is full - try re-formatting if you have no photos there. The SD functions the same as a PC hard drive, and if the directory 'tracks' are corrupt, anything could happen. Else try a new SD card.
Posted on Jul 04, 2008
dlundmark
Dave Lundmark
  • 797 Answers
SOURCE: I have a nikon cool pix camera that doesn't turn on
When there is nothing happening, it is hard to understand what is wrong.
Do the menus cone on or anything turn on?
If the camera comes on at all, then try setting all the menus to default.
If nothing comes on, no lights, nothing, then you are stuck.
If it will not turn on at all, I would recommend selling it at a site such as Ebay for repair parts, as is. At least you can get some money back, and buy another camera.
Also you may want to consider to call Nikon and trade-in or trade-up your camera for a re-furbished unit (a re-furbished unit will have everything just as it came from the factory. The support-repair department would be the place to get the number and information.
Posted on Oct 17, 2009
Anonymous
  • 617 Answers
SOURCE: My camera wont let me look do anything it turns on and thats it.
If you turn off your flash you might get a picture or two more,The flash consumes probably 3/4 of the battery.I have Sony,HP,Fuji,and Cannon cameras,they walk thru batteries like they're free for the taking.
Posted on Jan 17, 2010
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Oct 07, 2012
My nikon coolpix p530 wont turn on.
Mine did to i wait then it was fine! wow
Jan 24, 2018 | Nikon Cameras
I got this camera last June and it's been dead since January. Every time i try to charge it, it will not respond to the charge.The battery is completely dead, but when the charger is plugged into...
Hi, Sounds like the battery is toast. Batteries can stop charging any point in their life span. Usually I'd suggest just buying a new battery but because a battery shouldn't die like that within the first year I'd suggest contacting Nikon in your country and seeing what they'll do for you.
May 18, 2011 | Nikon Coolpix S4000 Digital Camera
My HP725 camera said the battery was low and I charged it but it seemed to run out fairly quickly and then I charged again, and now it's dead. Wont turn on to take pics. Is it the battery charger or the...
It sounds like the battery is end of its life. If you plug the power adapter into the camera, does it power on? If it does then it's the battery. (some cameras might requre you to have the battery in there..so put the battery in, but also plug in the power adapter and see if it powers on)
Mar 08, 2011 | HP Photosmart R725 Digital Camera
I just bought a Nikon coolpix 3000 yesterday and I pluged for charging 6:30Am this morning. However the charge light is still blinking now(4:00Pm)Is this something wrong??
There is a possibility that the lithium batteries are dead and won't charge up. You can go out and purchase 4 AA rechargeable batteries and put them in the battery pack and see if they will charge up.
If you still get a problem with the camera not charging, take the camera back and have it replaced.
NOTE: rechargeable batteries lose their life after a short while so it is a good idea to carry spares around with you.
Regards.
Jul 12, 2010 | Nikon Coolpix S3000 Digital Camera
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Lumix DMC-FZ18 wont power on
Leaving it in the on mode has totally depleted the battery, you say repeated charges fail. Usually leaving it on charge for overnight should revitalise it, if this is not so then the battery should be replaced as attempting to recharge it may cause it to split and spill nasty stuff onto things.
Dont take the risk with batteries in expensive cameras they are cheaper to replace than the camera itself. I remove the batteries from my camera at the end of any session and store them in a tupperware container in my camera gear. That way if they develop a problem it wont affect the camera. It also saves them from running down when the camera switch is left on.
Please rate my help++++Thanks for using FIXYA
Nov 23, 2009 | Nikon D300 Body Only Digital Camera
My cammra wont take pics and the lenze wont go down, i droped into the sand, got all the sand off of it though.
Dropped digital cameras are usually dead digital cameras. No matter how careful you are sand and dust can get inside and raise havoc with the internals.
Aug 12, 2008 | Nikon Cameras
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Nikon Coolpix S3300 Logo
Top Nikon Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you a Nikon Camera Expert? Answer questions, earn points and help others
