Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Rheem 81v40 Just stopped working
The 3A fuse on the white wire keeps on failing. what could the reason be?
Most likely bad PC board.
The fuse stops damage such as fire, but the PC board probably needs to be replaced.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other causes might be wrong polarity on 120 volt outlet, use a circuit tester to make sure the hot, neutral and ground are correctly connected.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 28, 2017 | Rheem Water Heaters
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 21VP50-1P - power vent running non-stop.
Rheem does not post service manuals, but other manufacturers do.
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also, scroll up on same page, on right side for heading title 'Pressure switch' for troubleshooting the pressure switch.
Don't forget to check anode rod to protect steel tank from rusting.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Oct 12, 2012 | Rheem Water Heaters
Code C8-76?
PC board is probably bad.
Rheem, Richmond, Ruud, Paloma, etc will send you another PC board, and hopefully the success rate will equal success rate of replacing motherboard on your computer.
Before calling service technician, copy following link for troubleshoot resources:
Aug 02, 2012 | Rheem Water Heaters
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Tankless water heater stopped working.
if you dont get any code then it is the circuit board..you will need to contact rheem or have a qualified technician check it
Jul 03, 2010 | Rheem Tankless Hot Water Heater...
Water Damage - Stopped working
Get a new one cause the water will rot and mold inside the base plate.  Have your homeowners insurance cover the cost.
Nov 23, 2009 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
60 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
