Sony Playstation 3 (PS3) Console Logo
Posted on Oct 06, 2007
Play Station 3
I just bought a used PS3 - I'm guessing I got burned, but thought I would just check with you knowledgeable people. The 5 prong plug that came with it won't work on my TV. So I went out and bought a ps3 - 3 prong cord, I Just get a black screen , no sound or picture. Tried a couple diffrent TV's and cords, and nothing ??
A
Anonymous
When you start your PS3, press the power button and hold it for 5 seconds. It will beep and reset the machine to the default settings. What is happening is it is thinking you are still using the other cable. Reset to default and it will recognize the new cable. Hope that helps.
Kingwin ez-dock 2 dosen't support 3 tb hhd
I bought a dual drive SATA enclosure and found out after purchase that only 1 drive could be active at any one time. I had to manually switch dives on and off. The reason was that the enclosure did not have a SATA drive multiplexer in it and neither did my laptop's Esata connector. A similar issue with USB.
tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
1helpful
2answers
My ps3 will not play ps3 games
This is a problem occurring in all the play station 3 consoles....... this is mainly because of pirated discs....if you are using good disc then go for downloading the Repair Guide it will resolve your problem (it contains N number of solutions )>>>>>>>> all the best ................................
CLICK HERE to download
1helpful
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Ps3 broken
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
That’s it! You can play your Play Station 3 again!
2helpful
Play Station 3 wireless controller will not ''link'' to PS3
Play Station 3 wireless (Intec) controller will not ''link'' to PS3 Console
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
2answers
Ps3
the console is probably PAL not NTSC
Check in the menu to be able to change the gameplay you might get luck
or
you might need a MOD chip of some sort.
Google it. You can find some good places.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Play station 3
you can reset the region code for playstation either by your disk that came with your playstation or by hunting down the code on the internet to reset region code
Top Sony Video Game Consoles & Games Experts
Jose Ramirez
Marvin
Marvin
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
