You are going to have to remove the battery to find out which one you need. For instructions on how to do this see: http://www.mademan.com/mm/fossil-watch-battery-replacement-guide.html. You can buy the battery at: http://shop.batterymart.com/search#w=fossil%20ch2599%20watch%20battery. Replacing a Fossil battery is delicate and tricky. Fossil recommends that you send it to a shop that specializes in Fossil watch battery replacements.
Use Rubbing Alcohol (70% Isopropyl Alcohol) from the drugstore. It is the easiest way to remove Mars Putty from natural fabrics and hair.Do a spot test first on a non-visible part of fabric to ensure the alcohol will not cause further damage. Liberally pour the rubbing alcohol onto the affected area. The Mars Putty should liquefy and become easily removed with a paper or cloth towel.
If your Mars Putty has adhered to a synthetic fabric such as nylon or polyester, Rubbing Alcohol may damage the fabric. Try WD-40 to loosen the Mars Putty and remove it from the surface.
If all else fails, take your garment to the dry cleaners and let them know your stain is silicone based.
Careful how you go about opening it. If it moisture is frozen to the seal and you rip it open you could damage your seal and then the problem will get worse not better.
What works best for me is to use a large putty knife with a hair dryer. I heat the blade up somewhat with the hair dryer and slowly work my way around the seal heating the putty kife blade with the hair dryer.
Once you get the door open, examine your seal very closely. If there are pitts or tears - replace the seal.
Also check to make sure that the evaporator fan is operating.
If you still have the ear hook you can find simple supplies at your local dollar store. I suggest adhesive putty. Once you have the ear hook back in place wrap the putty in tape or another type of material to prevent the putty from getting in your hair.
Remove the hair strainer or pop up drain assembly if so equiped and using a basin wrench or two crossed screwdrivers unscrew the drain basket and remove from the tub. Clean the tub and the back side of the basket and apply a generous bead of plumbers putty to the backside of the basket and reinstall. Tighten it down squeezing out excess putty, wipe off excess putty and you are done.
Some people use silicone sealer in lieu of plumbers putty and it will work fine but is messier in my opinion and makes dis-assembly harder.
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Ooops, in my efforts to find laser disc INFO I ended up in a completely irrelevant category; because there no longer exists a Laser Disc category. So I shall abandon the laser disc player as technologically obsolete (there goes still another species of dinosaur off to the fossil beds) and give up on seeing those movies in color.
good morning ! to remove the case back of your fossil watch,just snap the case back use the knife to do that ! but if your fossil watch is waterfroof design you need to use the wrench opener for treaded watch case back ! good luck ! god bless !...
