I have bought a new Nokia 3110C mobile, it worked well for few days, but latter it started giving a strange issue, it's Bluetooth has been affected, actual to explaing the issue in simple , whenever i try to share some data via bluetooth the opposite phone recieves data from my phone , but when the other phone try's to send a data via bluetooth, the other phone displays a message as Operation Failed, i am unable to understand why, since before sending the status my phone visible in bluetooth and even before recieving the data the confirmation request of Aceepting data from the other phone comes to me , but i am still unable to understand why i my phone is able to share , but not recieve data from other Nokia Phones or any other phone, Please help me find a solution to this issue. you can mail me at [email protected] with soulution.
Hi, your problem is need to reprogram your cellphone or try this also maual reformat to your cellphone just dial this *#7780# and default password nokia 12345.but before you that reformat you need to back-up your files to memory card and save your contacts to sim memory.after you that the cellphone is back to normal setting .i wish that i help your problem.thanks
I could not say whether the problem comes from mmc or from the set because 3110c has very weak software So firstly scan the mmc with updated antivirus.Secondly. Flash the set . Thirdly contact nearest mobile repairing center .
to remove password,update phone online with card in phone.format memory card with a card reader,remember to back up data.if this doesn't work maybe the memory card is bad.try formatting another memory card with phone to confirm.
Your phone is affected by virus... You need to format your mobile....Steps will be.
STEP: 1. Switch off your Nokia Mobile, STEP: 2. Press-> Call button, press-> 3, press-> *, STEP: 3. Now Switch on your Mobile.
Hope this will help you....
The Problem with Nokia 3110c – Switching off and automatically restarting
This is what happens. Nokia 3110 hangs, gets switched off and
restarts randomly. More often, it restarts around 3 times or so and
then gets switched off.
Possible Causes and Solutions
Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory. Solution – Keep the free space between 350 to 500
KB, so as to keep things running smoothly on your phone and prevent
Nokia 3110c from restarting. Cause 2 – Changing Themes – Some people have
reported that the phone restarts automatically when they try changing
display themes on the phone. Solution – Don’t get your phone loaded with too
many themes downloaded from the internet or atleast, don’t switch
themes frequently. These themes, mind you, also load up things into
your already falling Nokia 3110c phone memory. Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card. Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue. Cause 4 – Transferring data via Blueooth / USB data
cable (or) Updating Music Library – A few people have reported that
their Nokia 3110c mobile phone restarts when updating the music library. Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone. Cause 5 – MP3 files Solution – This may seem dumb, but consider
converting all your MP3 music files to WMA and then store them on the
memory card. Some users suggested this.
Also try this:----- It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime. but remember below DONTs 1] Don t try to change themes.{u have to stick with a theme} 2] Charge ur phone in ON mode 3] Dont fully discharge the battery 4] Start charging ur phone when there is only a bar on Battery indicator 5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again. if so Follow the above steps again. Good luck To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
My Nokia E61i sometimes starts up with the welcome screen and works normal for a while. Then sometimes the screen will flash on start up or continues to flash with spotted colors and not come on. Could this be a software problem?
Hi i m Almadani, i have Nokia 3110c,
in 3 or 4 days when i change my sim or insert a memory card,
so when i on my mobile after few seconds the cell switch off then on every time i on my cell then switched off after few seconds,
when i on with out memory card then the cell work normaly,
so waht i do for that?
can i formate it?
if i want to formate, then how i to formate?
reply me.
thankyou
