Question about Creative Labs Zen MicroPhoto MP3 Player
How to connect zen creative to pc - Creative Labs Zen MicroPhoto MP3 Player
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: zen vision m not recognized....
here, this is what I did to fix this problem. copy and paste from my original post on anythingbutipod.com
"My player is completely charged, I have XP w/SP2 - I can turn it on and listen to the default audio tracks and videos...I just can't get my computer to recognize it AT ALL!"
and then:
also, when I try to allow "everyone" to the USB....I found that in the advanced section I have TWO "everyones".
The one that says "full control" says "not inherited" in the inherited from column...the other says "read" and "machine\system\currentcontrolset......."
Should there be two of them in there??? Because when I try and switch the read to full control, it reverts back as soon as I select apply or ok....I tried deleting it but it re-creates itself soon as I go out of the window.
so I was told to do this:
Sounds like an NT problem. I don't know the exact steps to do this, but you'll need to remove inheritable permissions from that, which will remove the "inherited" attribute, leaving the locally-controllable one.
So open "run" command in the start menu and type "regedit"
From there follow this path...
"hkey_current_config" -> system -> current control set -> Enum -> USB
Do what I copy and pasted above and then plug your Zen V:M in and it should recognize it.
Posted on Jun 21, 2008
BlackHand-En
Neville Vyland
  • 68 Answers
SOURCE: i have creative zen stone plus 2 gb mp3 player
which Operating system are you using...>/??
have you installed the software provided by your mp3 player..??
Posted on Jan 28, 2009
Anonymous
SOURCE: Creative Zen - can't download music from XP SP2
I had my creative zen formatted to vista first now i'm using xp,the xp don't recognize it.
Posted on Apr 18, 2009
Anonymous
SOURCE: firmware update went wrong
What operating system are you using? The Zen Touch firmware update will fail in Vista or 7 -- you need to run the update from an XP install. Once you successfully get the 2.11 firmware on the Touch, it will then interface with those later OS's without difficulty. Also, what version of Windows Media Player are you running? Believe it or not, this makes a BIG difference. The latest Media Player 11 will cause the firmware flash to fail, as will WMP <= 9. I have three separate players that have experienced this problem, including one that had been disassembled THREE YEARS AGO after a failed flash, and was able to resurrect all utilizing this method:
(1) Uninstall everything Creative: the driver, Jukebox, etc. Delete the Creative folder from Program Files. (Some amendment to these instructions may be in order if you have a Creative sound card -- I have built-in Realtek sound so it didn't apply in my case). A restart may or may not be required: go ahead and do so to be safe.
(2) Plug the device in after restart. Windows will want to find drivers for it -- cancel that process. Open the Device Manager. The Touch should come up with an exclamation point next to it (since the drivers were not uninstalled): right-click and select "Uninstall." I have seen instructions on the Web to also uninstall all USB root hubs, but I have found that unnecessary and a pain if you have a USB keyboard and/or mouse. Unplug the device. Restart.
(2) If you are running a version of Windows Media Player not equal to 10, either install 10 (if you have 9 or below) or roll back from 11 if you have that. Restart.
(3) Plug the device back in. My supposition is that this is particular to WMP 10, hence the problems with other versions. The device should pop up as "Creative Zen Touch:" if Windows asks to find drivers, cancel that process, and the device should now come up as an "MTP device."
(4) Since the firmware flash failed, the Zen is probably in recovery mode. Launch the firmware updater software on the computer, and stay at the language selection screen. Choose option 3, "reload firmware," from the recovery menu. It will inform you that it is "deleting old firmware" and then will give you a short period of time with a dialog saying "start firmware update" on the Zen screen. During this time period (about 2 secs), press the language selection of your choice on the computer in order to start the update. It should go through successfully this time.
Posted on Jun 10, 2009
indus3
Hans De Becker
  • 212 Answers
SOURCE: my creative zen stone plus mp3 isnt recognised when connected by
first install all the drivers and software that came on the cd with the device. if the installation procedure asks to connect the device, connect it, if not, wait with connecting until after the install is complete and after you have rebooted the computer...
Posted on Jun 22, 2009
Where can I find the software of creative zen to connect to pc?
Hi Go to CNET.downloads Then go to creative zen version 1.28.0.0 Good Luck!! swampratt200 AAAEE!!
Jul 05, 2009 | Creative Labs ZEN V Plus MP3 Player
How can i connect my creative zen with my pc if i connect creative zen vith computer i cant find it in My Computer
I had a similar problem after I had used my Zen a few times. I plugged the device into my PC and it sounded like windows was trying to connect to to the Zen but didn't make the normal two tone USB device connection sound. It was more mono-tone. I tried reinstalling the Zen Media Explorer and that didn't do anything. I later looked at the Zen under windows device manager and noticed windows marked the Zen as having issues. I right clicked on the device and picked un-install driver. I then unplugged the Zen and plugged it back into my PC to allow driver re-install. I was able to connect to the zen after that.
May 27, 2009 | Creative Labs Zen Digital Media Player
My creative zen player used to connect to pc now it dosent
my pc stopped detecting my zen. i tried and tried on all different pcs and nothing would pick it up. couldnt even get the battery sign on the zen. thought it was knacked. then one day i plugged it in again, got distracted and walked away. when i came back about two hours later, it was detected and charging. thought maybe that it was so flat that it had to charge a wee bit before it could display anything or the pc could find it. i dont know, dont know much about these things. just a thought
Apr 24, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Firmware Problem
about this issue of creative zen wherein the device is not booting up to the normal os. and is not being detected by your computer, and giving you options to clean, reset, and format. my brother and i own creative zen, my brother own zen 4GB and i own 16gb. i don't have any problems at all. but my brother does. what i did is i just download the firmware version of my brother's zen that is missing which is version 1.03.04_0.6.1. unfortunately you will not find this firmware version at creative website. i checked a website and i found this. it's at http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Creative-ZEN-4-8-16-GB-Firmware-10304.shtml
just perform this steps and you're good to go.
1. download the firmware for your zen. 2. connect your zen to your pc. 3. run the executable file (firmware). 4. just follow the on-screen instructions on your computer and you're good to go.
hope that this step will help you guys out.
if you have any questions about fixing this kind of problem. or if this step won't help you. email me at [email protected]
i'll be more than happy to help you guys with this kind ok issue. god bless and enjoy listening to your favorite music.
Aug 06, 2008 | Computers & Internet
Pc not recognising creative zen micro
you had to install the creative-software BEFORE connect the zen for the first time.
1. disconnect zen.
2. install software (if you have already, go on)
3. uninstall the zen-driver
(winxp: Go to START->control panel->System
->Hardware->HardwareManager; uninstall zen with right mousclick->uninstall.
Not sure, if the naming is correct, cause i have no english winxp)
4. Connect Zen.
Hope that will help :)
Jul 08, 2008 | Audio Players & Recorders
Mp3 won't turn on
I do have the same problem. When i turn it on ti would simply turn 'ON' and on the screen it would write CREATIVE, and nothing could be done. no buttons work at all! please help!!
Jun 03, 2008 | Creative Labs Zen Nano Plus MP3 Player
Creative Zen
get the latest drives and firware at creative and try the recovery tools
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Aug 31, 2007 | Creative Labs Zen Micro MP3 Player
Creative Zen V Plus stops reading
· Make sure you have media player 11
· If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
· Download recovery tool off creative's website.
Aug 15, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
