Question about Sony DAV-FR10W System
Need to buy an ir receiver for a sony dav-fr10w
Where can i buy an ir receiver for a sony dav-fr10w
5 Related Answers
Anonymous
SOURCE: Anyone want to sell their Sony DAV-FC8 Receiver?
i have a sony dav-fc8 receiver not in running condition im willing to sell you can email me at [email protected] if your still looking for one i am going to sell it on ebay if you have an ebay account that might be better for you, the red light comes on the receiver but it is not responding that is the only problem, let me know whats up
Posted on Jul 20, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Posted on Feb 05, 2009
Anonymous
SOURCE: i changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
Posted on Apr 25, 2009
jerry_kramer
Jerry Kramer
  • 3904 Answers
SOURCE: no sound from sony dav-fr10w
First thing to check is the simple solution. Make sure you have the positive and negative hooked up correctly and also make sure that the wire ends are bared enough and that you have good clean contact in the snap terminal.
Posted on Jun 16, 2011
nicholas_arn
nicholas_arn
SOURCE: Need replacement speaker cables for dav-hdx576wf
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
Posted on Aug 27, 2012
Have a sony home theater system model davfr10w but the receiver is jumping from sat which is where Iwant if to dvd??? Can anyone give some input on this problem Thanks
I have the same problem. Purchased mine in 2005....went out in 2010.
My Sonny dealer could not fix. They talked to Sony and they wanted $230
to repair with no warranty. I'm trying to find a replacement but no luck.
Dec 02, 2012 | Sony DAV-FR10W System
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
Dec 16, 2007 | Sony DAV-FR10W System
No sound from sony dav-fr10w front speakers back surround works fine
Jun 13, 2011 | Sony DAV-FR10W System
Getting a loud hum only from video function.
Check your connections. Chances are you may have crossed the RED video cable and the RED audio cable.
Feb 26, 2011 | Sony DAV-FR10W System
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
I changed some video imput and now i cant see anything, only audio
Apr 23, 2009 | Sony DAV-FR10W System
Can the speakers be used with other Receiver? Like an Onkyo 706 for example. Thank You
Yes you can use the speakers and also the sub if it is a powered sub with a phono input,but be aware they are nowere near good enough for the Onkyo 706,look at the JAMO 102 sub and sats as a starting point if you have a small room,say 4meters x 5meters,or somthing from other good speaker companys to make the most of what is a hard hitting amp,but if you must use the speakers you have set the cross over to about 120hrtz to save the main speakers getting to much bass .
Hope this helps.
CABLE GUY.
Apr 20, 2009 | Sony DAV-FR10W System
Sony universal remote will not operate sony dream system
Feb 05, 2009 | Sony DAV-FR10W System
Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Jan 25, 2009 | Durabrand HT-3915 System
Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Jun 09, 2007 | Sony DAV-FR10W System
Sony DAV-FR10W System Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
