There is a little fuse inside the tv change that but make sure u change it for the right 1 tho or u can blow the main board up
Put your ear by the switch on the tv switch it on and off a couple of times if you hear a crackle its probable the switch its self, they always seem to go on these TWF LCD tv i have one my self i had the same problem but i knew when i heard the crackling i new it was the switch shorting the circuit so i just took the back off the tv makng sure i didnt lose any screws located the switch cut the switch out and just wired it straight through it didnt cost nothing only electrical tap. anyway i cut the switch linked the brown wire to the blue wire twice then i places electrical tap around the wires now you will see it working. all you have to do now is just turn it off at the wall or keep on stand by.
hope this is good help for you and anyone with that problem
I have exactly the same problem, is it working again yet?
