A message comes up that says "I NEED SERVICE Fault code 37 Please call for service" What exactly is a fault code 37 and what's involved with getting it fixed? For example is it a major, expensive fault to fix or is it reasonably cheap and easy to fix?
Posted by smosauges on
  • Bob B May 11, 2010
    Need more information to try and help you. Brand and model number would be a great place to start.
blueextc3221
  • 15,935 Answers
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pulling a vacuum on it with a shop vac. You may have an obstruction in the drain line or drain pump. It is also a good idea to check the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub and runs to the inlet side of the drain pump. This area can get clogged with small articles of clothing.
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the clear tubing (air hose) is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. This may generate an F27 error.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. Look for obstructions in the clean-out trap and impeller area of the pump.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off. You need to ask yourself if you find standing water in the tub when not in use.
5. The "Sud" error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent, HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause an over suds condition.
NOTE: Knowingly or unknowingly using the improper detergent on these model washers MAY void your manufacturer's warranty. Read all instructions and documentation that comes with the appliance, thoroughly.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a component failure (more commonly, the CCU or pressure switch)
Posted on Sep 15, 2010
Fault code 37
If you wish to get some details about washing machine service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 27, 2016 | Fisher Washing Machines
Check engine light came on and powertrain fault light as well. Code is P26DO. Anyone know that this means?
Possible Water Intrusion In Connectors ford has a special service message with this code SSM 32298
Special Service Messages SSM Page 2 Recalls SSMs TSBs call ford dealer and advise of code and ask which harness connector is involved
Aug 12, 2016 | 2015 Ford Fusion Hybrid
What is code 12 as an error message?
I wish to refer you to the list of Intuitive washing machine fault codes at the following website.
But first turns mains power off and back on after a little delay and check if fault is still there.
Fisher Paykel Washer Fault Codes
The fault code 12 means the flood protection error. It is likely the inlet water is coming at a faster rate then the controller of the machine expects. Try and turn down the inlet water tap to see if it makes a difference. However if the fault occurs within 15 secs of starting the wash cycle then I am suspecting some sensor failure, ie, the flood level sensor switch may be faulty. I am not sure what your exact model is so hard to recommend which part. But you should be able to work this out from the attached site for service manuals based on your model.
Jordans Manuals Your Online Service Manual Site
Aug 03, 2014 | Fisher and Paykel Washing Machines
Fault code 37 Yamaha V-Star 1300
Hi, Kenneth for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ERROR code 37
Yamaha Fault Codes
http://vstar1300.pbworks.com/w/file/fetch/94628933/1300VStarServiceManual.pdf
OEM parts for Yamaha
Yamaha 2007 XVS1300AW Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 15, 2012 | 2009 Yamaha V Star 1300
The check engine light on my Yamaha v-star 950 came on , code 37 , what is the 37 code?
Hi, Suzyscissor for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Check engine Error 37
Yamaha Fault Codes
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
YAMAHA XVS950A Owner Manual
May 06, 2012 | 2009 Yamaha V Star 950
2007 yamaha vstar 1300 engine code 37 comez up including check engine
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
Yamaha Fault Codes
Yamaha XVS1300A 2007 Service Manual
YAMAHA XVS1300A Owner Manual
Apr 18, 2012 | 2007 Yamaha V Star 1300
2007 Yamaha FJR 1300 AE error code 37
Hi, Vounari for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ERROR code 37
Yamaha Fault Codes
Yamaha FJR1300R Service Manual
Yamaha FJR1300R Owner Manual
May 17, 2010 | 2007 Yamaha FJR 1300 AE
My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Dishwasher error 1
Let me know the exact model and make, So I can assist you further. Also the exact error code.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. If the fault message reappears, please contact our Customer Service.
Regards
Ellin
Oct 04, 2008 | Dishwashers
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
