Question about Cecilware Kitchen Appliances - Others
Wiring diagram head unit
How to change wiring to change fryer from 240v to 120v
Posted by larry absher on
Angel Joseph Jr.
  • Cecilware Expert
  • 684 Answers
Hi there.
You may visit gmcw.com/foodservice-equipment/ for wiring diagram reference of your fryer model.
Regards.
Posted on Nov 22, 2013
1 Related Answer
bigg t
anthony james
  • 640 Answers
SOURCE: Change 208v heating elements to 240v.
If your supplying 240 vac to a 208 vac element it will work but shorten the life of it.Goto 3wire.com and register,they should have a 208vac element.The wild leg could also be an issue but if you get a 208 vac element it shouldnt hurt it that much.Why you would be getting a reading of 240 vac on l1-l2-l1-l3-l2-l3 is strange.Let me know.
Posted on Mar 26, 2009
Led wiring diagram on 240V AC
Is Led 120V or 240V?
For 120V you need a neutral wire.
240V generally does not have neutral wire.
http://waterheatertimer.org/How-to-wire-240-volt-outlets.html#120-240
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 14, 2014 | Hardware & Accessories
Replacing double pole 220 v with honewell ct410a two wire120/140v wiring diagram not clear
1 power wire (120v) will go to the thermostat and 1 power wire (120v) will go directly to the unit. The other wire on the unit will go to the other side of the thermostat. The safety precaution behind using a single pole to replace a double pole contactor is that you will always have 1 leg of power going to the unit. Many systems are designed like this from the factory, but it is always better to have a 2 pole to cut all power off to the unit unless it's in operation. The unit will still not work as long as it does not have both legs of power.
L1 to Thermostat T1 to Unit
L2 and T2 wired together.
This is only for 240v systems. 120v Will have 1 common and 1 power, therefore you will need to know which wire is which. Power to thermostat, common wired direct.
Nov 26, 2013 | Honeywell Programmable Thermostat Heater
Intermatic T103P Timer (120V) Wiring Guidance
Copy following link for T103 timer wiring options:
The clock motor is 120Volts, but clock motor can be changed from WH1570 to WG1573, and this action changes 120V T103 into 208-277V T104 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Jun 08, 2012 | Intermatic Hardware & Accessories
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
How many amps does the F14 draw?
For a 120V 1-phase unit:
15 amps; 1.8 kilowatts
For a 288/ 240V, 1-phase unit:
16.4amps/ 18.8amps; 3.4/ 4.5 kilowatts
You can download owner's manual at http://www.wellsbloomfield.com for your reference.
Regards.
Jun 16, 2011 | Wells F14 Deep Fryer
How to wire a intermatic timer T104 240 v to a 120v?
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Dec 26, 2010 | Intermatic T104 24h 208-277v Mechanical...
I need wiring diagram for Paragon 8154-20. The plastic board has melted
I think you have the 8145-20 240V
This is a time-initiated defrost timer
Paragon 8145 page
http://www.uni-line.com/modules/catalog/SearchResults.aspx?mode=productsearch&prodID=8145
Wiring for 8145
http://www.uni-line.com/images/docs/refrigeration-8140series-wiring.jpg
Wiring diagram shows both 120V and 240V
L1 L2 is 240V
L N is 120V
Website that explains defrost cycle
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 11, 2010 | Paragon 8145-20 Defrost Timer
Need to change wiring from 220V to 110V
Black or red is hot; green is ground; white is your neutral. The black should be for 120 and the red for 220.
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Mar 25, 2009 | Cecilware EFS-40 Deep Fryer
Kitchen Appliances - Others Logo
105 people viewed this question
Top Cecilware Kitchen Appliances - Others Experts
john h
Kelley Hopper
Paul Carew
Are you a Cecilware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
