I have a 6yr old LG Direct Drive front load washing machine. The drum makes a horrible loud grinding noise. It makes this same noise when you spin the drum by hand and will not drain water. Is this repairable? If so does anyone know how much?
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
