Sharper Image Hybrid GP  (SI724) Air Purifier Logo
Question about Sharper Image Hybrid GP (SI724) Air Purifier
Grid cleaning tool
My grid cleaning tool broke & I can not find a replacement
Posted by Dale Alig on
  • 1 more comment
  • Dale Alig
    Dale Alig Nov 13, 2013
    Its like a come with felt between its teeth. 5" x 5" including the handle with 18 teeth
  • Dale Alig
    Dale AligIts like a comb with felt between its teeth. 5" x 5" including the handle with 18 teeth
  • Dale Alig
2answers
Every time I turn on my Ionic Breeze the "needs cleaning" light comes on within a few minutes. I clean the grid but this keeps happening. What do I do now?
I have a ionicbreeze silent air purifier the "the cleaning light comes on within a few minutes . I have cleaned the grid but this keeps happening. What do I do?
6helpful
3answers
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
A spring leg (at the bottom of the grid) broke. The spring is still intact. Is the leg replacable or should I buy a new grid or unit?
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
1helpful
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
2helpful
2answers
Ionic breeze gp keeps shutting off and clean light goes on
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
2answers
Broken ionic breeze
Try this site to get replacement collection grids.....
They have several different ones listed so I just copied the webpage so you can see which one would be most suitable for your specific model.
http://www.thefind.com/search?query=ionic+breeze+collection+grid
Hope this helps.. :)
5helpful
3answers
Ionic breeze Quadra S1637
What is a grid and what is a grill when referring to the Ionic Breeze Quadra?
2helpful
3answers
Replacement parts
One of my tabs broke today after 5 years.  It looks like the tab piece just cleans the wire when the element is removed.  Seems like it does the same thing as the little beads that slide along the wire when you turn it upside down.  So I'm going to just use it without the tabs.
2answers
Broken wire on filter grid
Not easily but it can be done if you have superior skills with small tools.
5helpful
7answers
Unit seems stuck in the "drying grid" mode
I had the same problem with my GP. It has worked great for four years and only recently seemed to get stuck in this drying cycle. I cleaned the grid many times, cleaned the wires, cleaned the whole unit as much as I could to no avail. The trick: You need to clean the two metal prongs and surrounding area that insert into the bottom of the grid, when you inserrt the grid. they are sharp like nails, so take care. Use an alcohol based cleaners and clean the prong and around each base. This fixed the problem for me and she's back up and running well.
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
David Shaub
Colin Stickland
Colin Stickland
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
