SO THIS HAS HAPPENED TO ME ,WHAT I DID WAS GO TO SYSTEM SETTINGS AND FIND THE CALIBRATE APP IF YOU DON'T HAVE THAT GO TO THE APP STORE AND LOOK UP CALIBRATE APP . WILL HELP YOU FROM THERE
When connect ipod to computer, go to my computer. Click on ipod:-
-click on tools, go to folder options
-go to view tab
-check show hidden files
-a ghost like folder will apear: ipod control
-click on it and go to device
-there will be a locked file
-click and delete it
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." Good Luck, I hope this helps Please Rate me...Thank You
connect the ipod to system and when detected as a removable disk,goto ipod_control>device ,locate _locked and delete or rename the file....that will unlock your ipod
Allow the iPods battery to completely die and then fully recharge it. If it wont unlock then your displays touch sensitivity is not working and you may need to replace the display or it may be cheaper just to replace the iPod Touch
Friend, try online unclocking. go to www.nokia-calculator.com dont worry the software supports SONY ercson. just choose your model and type the IMEI then press calculate then once given a code type in your phone and it will unlock.
