Question about Hummingbird Humminbird 1155C GPS Receiver
Humminbird Matrix 12 sonar/gps problems
Before I installed my sonar/gps, I hooked it up to see if it worked properly, it did. I installed it and now the gps screen says i'm heading north when i'm heading south, same with east and west. I reset it to default settings and rotated the receiver and it's still wrong. The manual didn't say anything about it.
Posted by lindsellingf on
Mike Marcotte
  • 76 Answers
Make sure the 'North Up' is set to 'True' in the settings.
Best of luck
Mike
Posted on Sep 26, 2009
Will power up, but won't advance to menu
May require a software update.
register your unit at OnixSeries (this is a link to humminbird)
On your "My humminbird" page you will find free software updates for your particular unit.
download the latest update to an SD card and follow the instructions for the installation process.
Apr 20, 2015 | Humminbird 581I Hd Di Sonar/Gps Combo
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
I need user instruction manual
If you visit this url there is a download button that gives you the manual for this GPS device.
http://www.retrevo.com/support/Humminbird-12-GPS-manual/id/540bh447/t/2/
I will also post a direct link to the button itself.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=201775fbd475319d607a772a6cc14dea&modelid=540447&q=Humminbird+Matrix+12
Cheers!
May 02, 2011 | Humminbird Matrix 12 Fishing System
I cannot get a clear high definition picture on my gps. also no fish symbols on sonar. low voltage message keeps appearing on screen. any help would really be appreciated.
sounds like you might not be getting a full 12 volts DC to the unit. check the voltage with a volt meter,, and also check to make sure that your battery/batteries are in top shape and charging properly. ( one bad battery in a bank of many can cause voltage issues ).
c...
Dec 31, 2010 | Humminbird Matrix 97 Combo Fish Finder And...
I understand that matrix 12 is GPS ready ,how do i connect GPS to unit
The GPS system is already in the sounder, you need the G.P.S aerial which is purchased separately. I have this model with the aerial connected and it works well
Sep 12, 2010 | Humminbird Matrix 12 Fishing System
My Humminbird Matrix 67 shows 11.3 volts on the
Hi!
Go into the menu (press menu twice) and look for the alarms tab. There is a setting you can change for a low battery warning, make sure it is set to off or as low as you can get it. Also it may be time for a software upgrade (available at a service center)
Best of luck!
Mike
Jul 08, 2009 | Humminbird MATRIX 97 GPS Receiver
Need instructon manuals
Thanks I found copies on the net.
May 24, 2009 | Humminbird Matrix 12 Fishing System
Hummingbird Humminbird 1155C GPS Receiver Logo
199 people viewed this question
Top Hummingbird GPS Experts
Marvin
Marvin
Tom Chichester
Are you a Hummingbird GPS Expert? Answer questions, earn points and help others
