Does anyone have the engine wire harness diagram or schematic for 2002 lancer oz rally?
I am really impressed in your blog.....and Thank you for sharing this information...It is Very interesting..<a rel='nofollow' href=" http://www.pcmofnc.com/"> Trailblazer SS parts</a>
SOURCE: 2002 Lancer OZ Rally...
I had the same problem with my 2003 Lancer OZ. The oil level and pressure were ok. Car was fine with no light when starting. After 10 to 15 mins of driving it would come on when I was stopped. It would go away when I pressed accelerator. Try replacing the Oil Sending Unit. It's about $10 and easy to swap. That was my problem.
SOURCE: Loss of engine power Mitsubishi 2002 Lancer OZ Rally
Repair Manuals for the Lancer is like Hen`s teeth, however in your case look for the obvious replace the fuel filter, check the air filter also, start with the simple problems first
SOURCE: Mitsubishi Lancer OZ Rally 2003 hesitates while driving
before anything i had the problem and this is the way i solved it ... the lancer has 2 ignition coils in 2 cylinders what you do is take the iginition coil out of the cylinder that is misfiring and change it to another cylinder and put the car on the odb reader again it should change location of misfire .. then that would tell you that its the ignition coil thats bad i ended up getting my coil at the dealer for $110 ebay has some aftermarket pairs for $100 so you can get 2 now for the price i paid for 1 that will solve the problem guaranteed owne d a lancer for 5 years know the ups and downs to them
dirtyjerz908 at GMail.com hit me up
