Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Need operation manuel for AMF Paragon EC 74/120D Programmable timer control this is a vintage item
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Posted on Dec 30, 2009
SOURCE: I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Posted on Jan 21, 2010
SOURCE: i have a amf paragon model 4004-20 time switch
check the uniline website
Posted on Feb 26, 2010
SOURCE: How do you turn off
there should be a manual lever there that says on/off. or you should be able to turn the dial until you hear a click
Posted on Nov 13, 2010
SOURCE: need trippers for older unknown model number amf
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Posted on Jul 21, 2011
Feb 05, 2014 | Paragon Hardware & Accessories
Apr 03, 2013 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Jul 19, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Dec 12, 2010 | Paragon 4001-0G Defrost Timer
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Nov 17, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Nov 13, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Nov 27, 2009 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
507 people viewed this question
