Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
It says preparing user box
When i go to scan it comes up "preparing user box" do not know what this means or what i should do
Posted by Judy on
usman ashraf
    New Friend:
Please help I have Konica Minolta bizhub 287 when restart machine below ready to copy show indicator preparing scan/fax or preparing user box after 15min or 20 min machine ready during this indicator I cannot copy or print
Posted on Mar 28, 2018
C Putman
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. Just a guess. If you have an owners manual, I would check there to find how to solve the problemt. You will want to enter the "menu" if there is one, and discover whether you can turn solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section.
Posted on Nov 11, 2013
Troube code: C-E004. Error message: an internal error has occured. Turn OFF and ON the main switch. If the troube code appears again contact your service representative.
Find a local servicing dealer and ask what the error code means...
If they don't know or won't tell you, go somewhere else, even if that means the factory,
When you find someone who does know what it means and is happy to tell you, ask how much it will cost to fix...
Jul 25, 2016 | Office Equipment & Supplies
Tip
How to recover Excel 2007 password
Microsoft Office software developers have been paying more and more attention to the means of protecting users' information, and Microsoft Excel has not been overlooked. Recent versions of the program provide users with advanced features for protecting Microsoft Excel documents against unauthorized access of the information stored in them. The methods include completely blocking access to a document, forbidding saving changes to it. Besides, some expert team even designed Excel password recovery tool to recover Excel 2007 password for those who have lost Excel password.
Set a password to open or modify Excel 2007 password
Set a password to open Excel 2007
  • 1. Click the Microsoft Office Button 3dac3a8.gif, point to Prepare, and then click Encrypt Document
  • 2. In the Password box, type a password, and then click OK.
  • You can type up to 255 characters. By default, this feature uses AES 128-bit advanced encryption. Encryption is a standard method used to help make your file more secure.
  • 3. In the Reenter password box, type the password again, and then click OK.
  • 4. To save the password, save the file.
Set a password to modify a Excel 2007 Spreadsheet
  • In addition to setting a password to open an Excel spreadsheet, you can set a password to allow others to modify the spreadsheet.
  • 1. Click the Microsoft Office Button office.gif , click Save As, and on the bottom of the Save As dialog, click Tools.
  • 2. On the Tools menu, click General Options. The General Options dialog opens.
  • 3. Under File sharing, in the Password to modify box, type a password.
  • 4. In the Confirm Password dialog, re-type the password. Click OK.
  • 5. Click Save.
Remove password protection from an Excel spreadsheet
  • 1. Use the password to open the spreadsheet. (Note: If you don't know the open password, you have to recover Excel password with the third Excel password recovery tool)
  • 2. Click the Microsoft Office Button 3dac3a8.gif , point to Prepare, and then click Encrypt Document.
  • 3. In the Encrypt Document dialog box, in the Password box, delete the encrypted password, and then click OK.
  • 4. Save the spreadsheet.
Recover Excel 2007 password with Excel Password Unlocker Excel Password Unlocker is a popular Excel password recovery tool that can recover Excel password from Excel 97 to Excel 2007
on Jun 09, 2010 | Audio Players & Recorders
What does error code "Key Short Err" on Viking dual fuel mean?
Hello. That type of error usually means that there is a shorted button on the control. I don't know the model number so I can't look up the part. The button control panel is usually known as the "user interface" in repair lingo. Be prepared, the user interface panel is normally more expensive than the main control board. If the unit has "soft touch" buttons one of them probably is shorted out(giving the computer the impression that you haven't removed your finger and it's still being pressed). If it's one of the fancy capacitive touch panels(you just touch the glass to select), the circuit board has a defective chip and must be replaced.
Aug 31, 2015 | Viking Kitchen Ranges
Preparing for Scanning Application box
dear uninstall your printer driver .......
shut down your system and disconnect printer .....
open system and install driver ......
after installation connect printer
and enjoy it ..................
Nov 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
IBM Thinkpad T30 users manual
IBM Thinkpad T30, MT2366 & MT2367 Hardware Maintenance Manual
http://www.elhvb.com/mobokive/edwin/laptops/IBM/THINKPAD%20T30.PDF
Now,...I found this website that has the Users Manual for the IBM ThinkPad T30.
http://safemanuals.com/annexe_Install%20Guide_IBM_THINKPAD%20T30-_E.htm
You go to the right, where it has the orange bar, and ->User manual IBM ThinkPad T30 - Install Guide, in it.
Under this heading this is a PDF file icon. Under the icon it states -> Download the complete user guide
(484 Ko)
I clicked on it. It brings you to a page where you look at numbers that come tumbling down into 4 boxes.
You type the numbers as they come tumbling down, one by one in the box on the right.
(You'll see what I mean)
After the 4 numbers have been typed into that box, you go below, and click on Download the users guide.
I read their contract. You just use the down arrow on the right to scroll it down.
From reading it, it looks legit.
This is all I can tell you. I didn't download it, and don't know about it. Choice is yours now.
The first link on top I do know about. I downloaded it, and everything is fine. It's a Hardware Maintenance Manual, but may have some of the general user information you need.
User manual IBM THINKPAD T30 - Install Guide
Apr 19, 2009 | IBM 11P8273 for Thinkpad 14.1" Flat Panel...
What is a three user license ?
No you don't have to pay. A three user licence means that you can install Avanquest on up to 3 computers using the same product key that comes with the disk.
Apr 02, 2009 | Avanquest Computers & Internet
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Scanned sheets divided
In the preference section Uncheck "Detect Multiple originals".
Jun 09, 2008 | Agfa SnapScan 1212u Flatbed Scanner
Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
2,172 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
