Question about Akai Mpc1000 Sampling Music Production Station
How to connect my turntables to my mpc 1000
I just bought my first mpc ever. it's a 1000. I just need to know the proper way to connect my turntables to it.
Posted by burrellmusic on
soundproman7
  • 29 Answers
If your turntables use ceramic cartridges, you'll need to use a passive interface box that converts the unbalanced ( RCA ) plugs from the turntable to balanced ( 1/4" T-R-S ) plugs to connect to your MPC1000's stereo line inputs. If your turntables have magnetic cartridges, you will need an active phone preamp, check the music retailers catalogs or on-line there are many makes and models.
If you want to mix the two turntables ( sequeing from one to the other and back continuously as in a DJ setup ), you'll need a small DJ mixer.
Hope this helps.
Posted on May 15, 2009
I have a Mpc 1000 and i need a repair shop
contact the manufacturer and ask them if they have a repair facility they recommend
Mar 10, 2014 | Akai Mpc1000 Music Production Center
Help with using usb chord and sony vaio lap top.
Have you tried a different usb port or different usb cable also boot off your laptop and connect then connect the mpc 1000 and boot it up also make sure you have install the correct software for it
Jun 26, 2012 | Akai Mpc2500 Music Production Center
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
I have an older mpc 1000 & just today it started changing the programs & number of bars of the sequence I was making when I pushed the cursor.
There is probably a switch problem. IF these use the conductive rubber contact type switch buttons where a "pill" of conductive rubber is pressed onto a circuit board with traces, CLEAN the contact rubber AND the circuit board with 99% isoprophyl alcohol and Q tips. This type buttons feel "Rubbery and squishy" when pressed.
If the buttons have a hard tactile feel, then check for a bad button that might have broken internal parts and replace it... OFTEN you can tell by the "feel" when pressing compared to others.
In either case, disassembly and service is required.
May 12, 2010 | Akai Mpc1000 Music Production Center
Akai MPC 1000 is stuck in USB mode
I'm having the same problem. This is my second MPC 1000 and my first one didn't have this problem. I bought one of the first one-thousand MPC 1000's sold in the US. I loved it. I sold it for rent, boo hoo. I'm glad to have another one back in my life. But sad to see it having issues already. I've only had it for a week. I have emailed Akai regarding this issue. I'll post pack here if they give me a good fix.
Mar 25, 2010 | Akai Mpc1000 Sampling Music Production...
I have a Mpc 2000xl. I also have a small fast track m-audio. My bx5a monitor speakers the grey and red wire is connected to that. There is a guitar symbol in the back of my fast track m-audio. So what i...
The jack with the guitar symbol is a high impedance input for a guitar so you will get a proper level and sound when plugging your guitar straight in. All of your question did not appear in the post so try rewording it so we know what you are trying to do. Thanks.
Jan 25, 2010 | Music
Mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Jan 21, 2010 | Akai Mpc2500 Music Production Center
Akai Mpc1000 Sampling Music Production Station Logo
633 people viewed this question
Top Akai Music Experts
Mosaub Al Masri
Mosaub Al Masri
rhodesworks
Becketts Music Ltd
Becketts Music Ltd
Are you an Akai Music Expert? Answer questions, earn points and help others
