Cameras Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't know how to open it to put new film in?!?!!
I've seen a lot of cameras in my day, but this is a new one for me. First of all, I had never even HEARD of Tashika cameras until my ma found one for me at goodwill for like $3.00. It was a bargain! It looks like one of those 60's jobs that don't have a battery. Anyway, my problem is, I don't know how to open the film "door" to place new film inside. Maybe someone can help?
CameraR
Level 3:
  • Cameras Master 4,738 Answers
  • Posted on May 03, 2009
CameraR
Cameras Master
Level 3:
Answers
4738
Questions
Helped
1195756
Points
12483
Do you mean "Yashica"? If so, pull up on the film rewinder knob on the top-left side of your camera. The film door should pop open.
I still have my old Yashica "Electro 35". Don't use it anymore as I've gone digital, but it still is a pretty cool film camera.
  • CameraR
    CameraR May 03, 2009
    By the way, if your camera happens to be a Yashica Electro 35, hang onto it. It's a very nice camera, and has quite a large fan base following, even these days. Do a quick Google search to see.
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
tip
Stuck Film Advance in Manual or Auto Wind 35mm Cameras
I've been seeing a great number of posts from people requesting help with a stuck film advance feature on their 35mm film cameras (you remember "film", right?) Normally, there are just a couple of things you can try to fix this issue before you'll need to find a professional to repair your camera - if it's even worth it. On that note, a lot of people still have film cameras for nostalgia purposes but there are still some hold outs that enjoy film. Finding a repair shop for an older camera isn't impossible but they are getting scarcer. Google "FILM CAMERA REPAIR" and see what pops up in your area!
MANUAL ADVANCE CAMERAS:
There's a complex number of actions that must work properly in order for you to advance the film in your camera using the manual advance lever. Gears, shafts, bearings and springs come into play and like a clock, they need to mesh together or the advance mechanism comes to a screeching halt. Well, you'll be the only one screeching, most likely but you get the point. If any of those parts break or become unaligned, or if some foreign matter like dust or dirt gets into them, the same thing happens. However, there are sometimes a few things you can try that might prevent you from sending in your camera for professional repair. I caution you about opening your camera yourself unless it has no real value to you because the interior of a 35mm SLR camera is pretty complex, even more so that a clock. Chances are you'll do more bad than good. With that said, try these options:
Film Jammed - Won't Advance
Sometimes the film will jam in the canister, or in rare instances, isn't actually as long as it's supposed to be and can reach the end of the roll before the camera indicates it has. If you suspect this has occurred then push the film release button and try to wind the film back into the canister before opening the camera. If you don't care if the film gets exposed feel free to do this in the light. It's much easier!
At times the film may also pull lose from the canister and roll completely on the take-up reel. If this happens you'll need to take the camera into a completely dark room with the light-proof film container, remove the film manually from your camera, roll the film up and put it into the light-proof container, close it tight and then seal it with electrical or duct tape. Also let the lab know this has happened so they don't pop up the container and expose your film thinking it is still in the canister.
Advance Lever Stuck
If the actual film advance lever is stuck and won't move, about the only option you have is to open the back of the camera and be sure nothing has jammed in the gears or sprockets of the take up reel or film path. If that doesn't fix the problem try pressing the film release button, wind the rewind lever a bit and see if the advance lever engages again.
If the lever just flips back and forth with no tension at all then something inside has broken and your chances of repairing it yourself are almost none. Most film cameras are getting on in years and will just naturally begin to break down over time. There may be no option to even fix your camera unless you find a similar model for parts and send that along to the repair shop. Make sure you get the parts camera back as you may need it later! If you like tinkering and the camera isn't one you'd miss if you couldn't fix it, then you could always give it a shot yourself. You can pick up a set of jeweler's screwdrivers and pliers from the web or Radio Shack for under $20 and find old film cameras on EBay or Craigslist at a decent price. Just be sure they don't have the same problem as your current camera does!
Grinding Noise When Advancing Film
This is most often caused either by a broken part, metal shavings or dirt/debris in the winding mechanism. Again, if you feel comfortable doing it yourself and it's not an expensive collector's model, you can try to repair it yourself. Hunt down a PDF service manual for your camera on the using Google web (a lot of collectors share them) and it should show you how to remove the cover to see the winding mechanism area. Look for debris in the gears and springs and remove it with short blasts of canned air but be sure you hold the camera so any debris falls out and not further into the camera. You can also use Q-tips dipped in alcohol to remove any debris, but don't use water, and let the area dry completely. Once you've done this, you'll need to apply a light lubricant to the area but only if it was lubricated before you cleaned. Use thin white lithium grease or an oil or grease used by clock repair shops and apply it with a toothpick as you don't need much. DON'T USE WD-40! It will do more damage than help.
MANUAL ADVANCE CAMERAS WITH MOTORDRIVE ATTACHMENTS:
These are manual wind cameras like the Minolta X-700 or Nikon FM2 that have an attachable motor drive that winds the film for you. Pretty much the same suggestions previously noted can be tried with a couple of exceptions:
Check the batteries and contacts in the winder making sure they're clean and not bent or broken. You can clean battery contacts with a CLEAN pencil eraser or alcohol and a Q-tip. Blow any dust and debris out of the compartment afterwards.If you still experience problems remove the winder and be sure the coupling that locks into the bottom of the camera to wind the film is not jammed or damaged. With batteries in the winder and the power turned on, look for a series of contacts on the top of the winder that mate with your camera. Be sure these aren't dirty or broken as well. Using a paper clip, you should be able to short one or more of them to another to activate the winder to make sure it works properly.
When All Else Fails - A Bigger Hammer
If none of the previous suggestions work and if, ONLY if you don't value the camera for collector's value a firm tap might work as a last ditch effort. I once had an old Minolta SRT that locked up solid. I didn't want to bother with trying to open it up as I only used it for a shelf display so I took the lens off, used a wad of very clean, soft foam to hold the mirror steady and wacked it twice on the counter. Not enough to damage the camera body (or the counter!) but a good smack. Whatever was jammed came loose and the advanced began to work. As I said, I only use it for display so I don't know if it affected the shutter speeds, etc. but it worked and cost me nothing but time.
AUTO/POWER ADVANCE CAMERAS:
Newer "old" 35mm film cameras used a power winder motor to advance the film and **** the shutter. If you experience a jammed advance on these cameras, check the film path, sprockets and make sure they are clear and move freely, as I described previously. Try the film release button and see if that will release the drive as well. Another option that has worked at times is to remove the film, lens and all batteries from the camera (including any date/time battery) for at least a day or two to see if the camera will reset itself. This worked for me once with a Nikon N70.
As a last ditch effort, the table smack might work as well, but I make no promises and it's all your fault if you damage the camera beyond repair... or your furniture!
on Jan 06, 2015 • Photography
1helpful
5answers
I'm thinking of buying a heated cat bed for my cat, are there different types?
There arelots of different types of heated cat beds. I\'ve seen lots of different shapes,colors, materials etc. You can even personalize your cat bed.
Jul 23, 2012 • Cats
I just loaded my new Fujifilm instax 210 for the first time with the correct film, loaded properly, and the prints are coming out black!
Well, black prints on an instant, or any camera, mean that they're unexposed. So, there are a few things to check - but in your case all will probably mean losing your remaining photos.
First, when you loaded the film, did you remove, or did the camera spit out, the initial black cardboard leader? If not, this is the source of your problem. This piece must come off the film pack first otherwise nothing else is going to work.
If that came out and you're still not getting photos, you're going to need to verify that you're both using the camera properly, and that the camera is functioning properly.
You'll need to be sure that you're getting enough light to get a good photo - darkness isn't going to give a good picture, but in some situations with some high speed films, neither is too bright of a condition. I've had this problem with my polaroid camera. The camera can't compensate for an extreme high-speed film and bright sunlight so it's not even giving an exposure. Don't ask me why, but it happens. If there's an option to change settings for outdoors/indoors, try that.
If that's also not your situation, you'll need to find a way to verify that the camera's shutter is actually opening and working properly. That's easier said than done, but if the other two situations don't help, feel free to contact for further assistance.
2answers
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
I've taken many photos so far with my Canon T70 but have no idea how many and when to stop.. i'm not counting the number of photos i've taken, haven't heard any beeping and don't know...
The maximum number of shots possible is 24 or 36 depending on the film length, although sometimes you can squeeze an extra one out of a film. If the film loaded correctly you will get a frame counter in the LCD. If the film did not load correctly, then you have not taken any photos as the film is still in the canister and unexposed.
Take the camera to a totally dark room (and I do mean absolutely pitch black) and open the camera. if you can feel the film canister and just the short leader then it didn't load and you can turn on the lights and try loading again. if there is just the canister and no film sticking out, then the film has rewound and you can turn the lights on and send the film for developing to see if the camera worked. If you feel film going from the canister right across to the take-up spool, then your film is still being used and you should close the back of the camera before turning on the lights again. The latter does not necessarily mean that your camera is OK though as it should be showing frame numbers, but it may be usable still. If after a few more shots the camera is still behaving just the same then it's got a fault.
A faulty t70 is really not worth repairing. It's complex, spares are mostly unavailable, and they are almost worthless even in perfect condition. Any of the earlier non-t-series Canon FD-mount bodies are far better and a lot more fixable. They are also usually near worthless and can be picked up free or very cheaply, but as they have less to go wrong and were designed with repairs in mind then many common faults can be fixed.
Where is the serial number on a Polaroid Spectra Onyx? I've inherited one and want to find serial number. I may sell it on eBay and don't want to chance someone to return a different broken camera to me. I...
I haven't seen a Spectra Onyx for years, so cannot directly answer your question, but with respect, it's not really an issue.
Your camera is obsolete and film is no longer available so they're completely unusable. They weren't popular when new but are certainly not rare either and are only of interest these days to collectors who want them for display only, but even then they must be cosmetically perfect and preferably boxed. Even then they're worth about £10-£15 at most on a really good day. Hopefully you'll be lucky and get more; just sell it as sold as seen with no returns and you won't need the serial number.
May 24, 2010 • Photography
I want to ask a friend to bring a few packs of Instax film from the US for me and I want to know how the x ray machines might affect the undeveloped film. My friend would bring them here to me in Mexico...
Films 800 and higher (800, 1600, 3200 iso), should not go thru the x-ray. I recently took a lot of films on holidays in the US, the security staff were very helpful and understanding. I put my high iso films and instax in a clear ziplock bag, and asked for hand inspection, they do a swab to check for whatever they are screening for. The x-ray machine has a sign that says films under 800 are OK in the machine, that means 400, 200, 100 etc. not 800.
There is a risk if you put it in the checked baggage, as sometimes this is x-rayed, and that's supposed to be even stronger x-ray.
So, take your film in a clear ziplock to the security people and ask for hand inspection due to 800 iso. Couple of times I was asked extra questions, they asked to see the camera, I explained it's big in Japan. Another time they asked me to open the package, opening the cardboard package, and even opening the silver wrapper is OK because the film is still safe inside it's black plastic cartridge.
Film is stuck in kodak advantix tried a new battery and nothing happens - camera doee nothing
APS cameras are very rarely seen these days because the film loading and advance mechanism was poorly designed and engineered from the start.
Your fault is very common and given that the camera will be irreparable anyway (no spares, plus the small problem that the camera was never designed to be repaired anyway) then you need to decide whether to just chuck it away or whether to break open the camera in total darkness and manually rewind the film back into the cassette for developing.
Bat indicator blink´s
Hi , clean the battery terminal having acid rust to contact will positive and nigative terminal.Open the lense to release the shutter miror might open , check the camera option select in auto or manual not in lower speed can cause stuck.open the film compartment and load film .
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
